The symbols used in the canvas are also edited in the Presets panel
I am trying to organize the resources in the Presets panel. Today I realized that if I use a symbol ( a layer with 3 objects) in a project and delete an element from it, the changes also take place in the panel. Is this effect intentional? I don't think this is a good solution. Unless there is a possibility to disable such an action, but so far I have not been able to find it. Sometimes after restarting the application it returns to normal, but I lost some of the presets already.
@encart This looks like a bug if happens with the Presets panel, these symbols should be fully copied.
@vectoradmin Could not replicate this one. I am using the Presets panel, and creating symbols into the Presets group.
Modifying the original symbol did not change the created symbol.
I might be doing something different.
@vectoradmin
Here is what i've got.
https://recordit.co/cSSiRMeMFq
It may be the problem with text only.
@encart Got it replicated! Will be fixed.
@encart This has been fixed in build 1.0.044
