Imported SVG's are invisible until ungroup & position of imported files
- Everytime I import some SVG file to document, I can see it only when I ungroup it.
 - Imported files (svg's, images) are placed in the left bottom corner. Could you change the position to match the current view.
@encart I tried to replicate this on Windows, but could not.
Did you use the File -> Import command, or drag&drop the file into the canvas?
@encart Could not replicate this issue (on Windows or Mac). Will keep it open for now, let me know if you have more info.
@vectoradmin Try this in a new document:
- Create a rectangle and deselect it.
 - Import any SVG file.
@encart Got this replicated.
It is just a missing refresh issue after importing. Press Control+R on Windows to refresh after the file is imported.
Added to the back, will be fixed in the next build.
