Accidentally going into isolation mode
I often run into the issue that while using the Transform tool to move an object I accidentally trigger isolation mode. This is quite annoying when this happens a lot. Is there a way to make it harder to enable isolation mode, perhaps some kind of preferences setting?
@postdes I don't think there's a setting for this in the app's Preferences.
But this unintended double-clicking might be a hardware issue. Is it happening with a mouse? You can try with another one if possible, and report if it does the same.
@postdes I agree the isolation mode is a little too jumpy. It happens a lot when I use my stylus and I'm just clicking to get a node and I miss and click again
@postdes I add this to the backlog. I'll think of an improvement.
@vectoradmin This is happening with a Wacom Intuos 5
I'm using a stylus with a Wacom cintiq
@postdes @Boldline Added an option (Preferences -> Document Editing -> Double Click with Tablet) to disable double click in the document editor when using tablets (mouse will still double click).
