Paning is locked when Simplify Path popup window is active.
I used mouse and Spacebar and both were inactive. Only zoom in/out worked. As I remember i had that problem with other popup as well.
@encart Everything is blocked when the Object -> Simplify Path popup window is active, including zooming.
Should it be a non-modal popup (like the panels)?
If that is the reason, than in my opinion we should change it. It's hard to see result when preview is on, and object is complex.
No, zooming is still possible. I can zoom in/ out with scroll but is not focused on target.
@vectoradmin The modal windows of effect settings should also allow panning the canvas — if they are displayed over the object you're editing you need to pan the view to see what the effect does.
@b77 I add this to the backlog.
@encart @b77 The simplify path view has been replaced with a floating view. It is auto confirming (as the smoothness is adjusted).
Selection can be changed while the view is on.About the Shape/Image effects modal view. This remains modal for now (no access to document while the view is open). The Shape/Image effects panel can be used for non-modal editing.
@vectoradmin I like the way the Simplify panel is coming together. Would it make sense to have a ghost image of the original shape there so the viewer can compare the simplified path to the original shape?
Maybe have it be a toggle - to view original shape or turn it off?
That was the first thing I thought of when I used it, because I started to forget where the shape started from
@Boldline I add the ghost image idea to the backlog.
