If transform selection box is not set at 90 degrees, it creates a wonky offset path
I noticed a few times now when I try to add an offset path to an object that has been angled differently than the standard 90 degree position, the offset path has issues. Here is the video for this issue
I attached the file here:
0_1667848746182_wonky offset path.vstyler
@Boldline Added this to the backlog, will try to fix ASAP.
@Boldline This issue should be fixed in build 1.1.072
