Brush color switches to white when change is made to brush size with bracket keys
Another video example from a new file - seems to happen when the default color is set but if you swap the brush color to something else, it will not switch to white again
0_1669083966475_brish went to white when editing brush size.vstyler
I do have the "Update Brush Tool Width" selected if that is a factor
@Boldline This issue should be fixed in build 1.1.072
