    3. Resolved 1.2 bugs
    Resolved 1.2 bugs
      Cannot select all contents directly
      • monsterfox
      2860
      @monsterfox Not clear which tool was used for selection? I tried both the Transform tool and the Node tool and all shapes were selected.
      file error
      • monsterfox
      6055
      Could we implement the "Purge" tool? @VectorStyler I love the history panel and activity info options and I always keep them active when I am creating a design in case there's an issue I run into or if I need to go back and make an edit or alternative version of the art. Once the project is over and the art is complete, I rarely need the history and activity info anymore, so I usually erase them at that point. Perhaps a "purge option that makes it easy for the user to checkmark all options to be purged would be helpful - then this can be accomplished easily in one overall action
      Not sure if this is an isolated case.
      • monsterfox
      4213
      @monsterfox Did not crash here. I will look into the crash logs.
      PDF/X
      • kisanti
      5116
    • VS textbox don't receive 2nd line
      2208
      @Raaskot Cannot replicate this, tried to paste similar text with multiple lines into the same file. Send me the text file from the recording (by email) could be some special character blocking it.
    • Problems when I open pdf-files generated by VS i Adobe Illustrator and Print Studio
      3258
      @Raaskot I will try to find out what is the problem here. The exported PDF file seems to be correct (per Acrobat, but also Preview), but AI CC clearly has a problem here also. One issue might be that AI CC does not support the full PDF standard for character encoding, in which case I have to try to find a supported encoding scheme.
    • Adding a new style with a selected paragraph leaves the font family field blank
      3598
      @Raaskot Could be a bug, I will try to replicate and fix.
    • textbox move with odd offset
      2165
      @Raaskot There is a transform on the parent of the text frame that causes this issues. I opened a bug and will try to fix this for the next build.
      VS 1.2020 from App-Store doesn't start
      • Wurstkäs
      3823
      Thank you very much and many greetings to Finland!
    • Spelling error in hover tag info in Paths panel (both new feature additions)
      2371
      @Boldline Will be fixed
      After rotating the angle in the Repeater, the color display is incorrect
      • Li Xiao
      2754
      @VectorStyler Thanks. Fixed
      The Symmetrigon tool cannot add any open path shape objects
      • Li Xiao
      2961
      Issue with real-time refreshing in Repeater
      • Li Xiao
      5457
      @VectorStyler Fixed. Thanks
    • Using node Tool nodes have only half the size of the size using the transform tool
      • chessboard
      4126
      @VectorStyler That sounds good! Thank you!
      strange bug
      • monsterfox
      2820
      @VectorStyler This is a problem caused by the dxf file I imported from the outside. The operation of simplifying the path is relatively uncontrollable, which easily causes the curve to deform. In most cases, people just need to reduce the anchor points and do not want the curve to deform too much.And the second problem I mentioned above also exists at the same time. Still, please find the cause and fix the problem.THANK YOU.
    • Node editing impossible - hidden objects
      2446
      @Ingolf Yes, this can be replicated here. Editing hidden objects is problematic.
      Grouped Object and Text Fame Editing Problem
      • MWK
      2293
      @MWK Welcome to VectorStyler. Yes, there seems to be a bug here and can be replicated here also. I will fix this ASAP.
      Select similar, then by style...
      4692
      @Pat Got it, I will try to find out what is causing this.
      A minor thing in 1.2 new Launch Panel
      2738
      @VectorStyler this is solved, looks fine now
    • Borderline Flicker in Menubar on Windows 10
      • debraspicher
      8024
      @debraspicher said in Borderline Flicker in Menubar on Windows 10: That's funny. I only have that one display @ 125% scale because Serif/Affinity refuses to fix their rendering bugs. Serif is a company with a big mouth but tiny fingers. Welcome to a program with a scalable user interface and bugs that fear for their life. Bugs don't in Nottingham.
