      Crash During PDF Export
      • gotanidea
      5971
      @VectorStyler Thanks Admin
    • Rename Layer Object using Object Options Panel
      9628
      @Igull said in Rename Layer Object using Object Options Panel: If the object is locked This must be the cause.
    • Internal Filename
      6595
      @VectorStyler OK, I'm sure there will be a reason for that It's not an issue. Neil
    • Inside Erase Bug
      5152
      @VectorStyler said in Inside Erase Bug: @Igull This issue should be fixed in build 1.1.080 Yes, definitely fixed, thanks ! Neil
    • The imported SVG file is cluttered with unnecessary curves
      4981
      Yes, the problem does not occur. Thank you
      Tilling Pattern
      3336
      @Pat This issue should be fixed in build 1.1.080
    • Alt+ Scroll wheel creates new obcjects while changing width/height value in Transform Panel
      9097
      @encart This issue should be fixed in build 1.1.080
      Wrong and to many colors in Image to color palette
      7480
      @Subpath This issue should be fixed in build 1.1.080
    • Rectangle tool with stroke set to outside or inside causes issues
      5074
      @Boldline This issue should be fixed in build 1.1.080
      Create composite shape make program crash
      • mtinra
      3797
      @mtinra This issue should be fixed in build 1.1.080
      Selected object lost when open edit color dialog
      • mtinra
      3847
      Issue when switching from tablet to mouse
      7837
      @Pat I have made some changes to how the mouse/tablet switching is handled on Windows. But since I could not replicate the bug, I cannot be sure if these changes fix the issue. Please check if the problem occurs again.
      Vector Styler UI text and icons not scaled correctly in multiscreen/multi resolution environment
      • GraphicsGuy
      3603
      @GraphicsGuy This issue should be fixed in build 1.1.080
      Fonts activated in FontBase doesn't work in VectorStyler
      7744
      @VectorStyler This issue should be fixed in build 1.1.080
      Repeater panel -> Repeater Geometry: flipping not functional
      3501
    • Select all hidden/locked objects doesn't work in Layer Panel context menu
      3384
    • R
      Moving selected objects onto a target layer
      • Raven
      6314
    • Minor Menuitem Changes
      5326
      App Freezes If Words Get Deleted using Backspace
      • gotanidea
      4634
      @gotanidea This issue should be fixed in build 1.1.080
    • R
      Transform Move of multiple objects
      • Raven
      3351
      @Raven This issue should be fixed in build 1.1.080
