      Strange behaviour colors
      • FastVector
      7166
      I've repeated what I've done before, but now everything seems fine. No idea what caused the problem.
      This topic is deleted!
      • jSayal
      UI Display Issues 1.1
      • FastVector
      5109
      @FastVector said in UI Display Issues 1.1: But you can also maximize a window by draging them to the top of Windows, and then the problem occurs. Yes, this can be replicated here also. I will try to fix it as soon as possible.
    • I
      duplicate object lag & snap indicators invisible
      • Iriseg524
      16715
      @Iriseg524 You should have a new license now.
      Png display issues
      • William Kansepa
      3808
      @VectorStyler This issue has been resolved in VS 1.1.116. Thank you so much @VectorStyler!
    • Copy/paste objects from Affinity Designer to Vectorstyler- bug
      • visualrevolt
      3970
      Designer vers 2.2.1
      Issues with The Artistic Brush
      • Li Xiao
      5709
      @VectorStyler Thanks, I got it
    • Eraser Regression
      4865
      @Igull said in Eraser Regression: assumes that shape shouldn't be broken and the fill removed Yes, it only breaks apart if the eraser results in separate paths.
    • O
      Adding a Anchor Point After Path Reversal
      • oleGraf
      7012
      O
      @Boldline Thank you for your video. It does a good job of illustrating my original post. Appreciatively.
      The shapes corner bug
      • Li Xiao
      3747
      @VectorStyler The bugs have been fixed Thanks
      Flip repeater content problem
      repeater • • Li Xiao
      6602
      @VectorStyler fixed thanks
      Beta 1.2: VS crashes when a panel...
      7854
      @VectorStyler said in Beta 1.2: VS crashes when a panel...: @Pat said in Beta 1.2: VS crashes when a panel...: because there is no 'send' button Just use the "Close" button, crash reports should be sent. Fine, it is what I did
      B1.2: issue when trying to adjust the width of the panels when docked
      3050
      @Pat Yes, this is by design for now, the first column will just move.
      Some issues regarding the mesh
      • Li Xiao
      4059
      @VectorStyler said in Some issues regarding the mesh: @Li-Xiao Yes, mesh inside artistic brush will not work for now. I added this to the backlog and will try to find a solution for this in the future. Meanwhile, keep the content of artistic brushes to pure vectors. Looking forward to updates regarding the mesh. I have used Mesh Tormentor and very like it www.meshtormentor.pp.ua
      Image effect
      10724
      @Pat Got it!
      Document format - the wrong one
      3920
      @VectorStyler even if I make a new format from scratch, I get the square format back.
      Shape effect
      5229
      @Pat said in Shape effect: is it a new feature to be able to get a stroke on an object with a colour mesh ? Yes, it was requested. The problem here is that the shape effects cannot subdivide the mesh, but can subdivide the object shape.
      Spiral Wire Size and Accuracy Issues
      • Li Xiao
      3000
      @Li-Xiao I added this to the backlog as a bug.
      The shape text corner bug
      • Li Xiao
      3786
      This error has been fixed. thanks
      Paning (H or Space shortcut) doesn't work after applying effects
      3224
      @Harry Yes, this is by design. The pan tool (or any other tools) are blocked while in a modal view. I will try to improve this in the future if possible. Meanwhile, it is better to use the Shape Effects panel to edit effects and have panning available also
