Inside Erase Bug
I've attached a vid of an odd issue ...
https://recordit.co/uGkOyVjBxi
The rectangles are grouped in sets of three. If you erase any part of the inner grouped rectangles first, the erase tool doesn't erase correctly.
However, if you erase part of the outer rectangle first, then the inners erase OK. It doesn't have to be rectangles, any enclosed and grouped set is the same (they have to be grouped). It doesn't matter if you selected the group first and then select the eraser tool (as it says in the manual) - I've found that normally, the eraser tool works just fine without selecting the object first BTW'Separate path with eraser tool' is set to ON in prefs.
Neil
@Igull Send me the file with that rectangle example. It is either the fill style or the closed path state.
Just sent.Neil
@Igull This issue should be fixed in build 1.1.080
@VectorStyler said in Inside Erase Bug:
Yes, definitely fixed, thanks !
Neil
