    • Split text cannot properly work with more than one group of live text selected at one time
      2844
    • Union operation not merging all offset path shapes
      5189
      @Boldline your always welcome
    • Duplicate stops functioning after a session of VS use
      2782
      @Boldline I added this to the backlog, I will try to find out what could cause this issue.
      Miss the Tip on Pencil and on Path Sketch Tool
      2450
      @Subpath Looks like a bug, will be fixed ASAP.
    • Pan tool not working right after modifying node roles
      4220
      @Boldline Yes, can be replicated here also. This was the same before. When clicking outside of the canvas, the keyboard input is assigned to that part of the UI. To have the panning active again, click on the canvas.
      Alignment: objects order
      2752
      @Pat Depends in what order the alignment is done. You may want to use the geometric order (bottom-right button) in the panel:
    • Second cut through with eraser tool erases first cut shape
      3507
      @Boldline Disable the "Separate path with Eraser Tool" option for now.
      Repeater crashed VS
      14897
      @VectorStyler It was not so large (did draw within the artboard) but I should have setup the Repeater feature before applying... did not think about it, though I didn't have these issues with 1.1.079.
      Right-click menu look weird after undo (1.1.073 Win10)
      • Gremriel
      7603
      @VectorStyler thanks.
    • Isolated mode doesn't hide other layers
      5471
      @VectorStyler said in Isolated mode doesn't hide other layers: @Ingolf This issue should be fixed in build 1.1.080 Yes, confirmed fixed, thanks!
      Copy and paste problem
      9486
      @VectorStyler yes, is fine now
    • Selection Marquee disappears
      • syllie
      6731
      @syllie It might have occurred after a longer time use. Let me know if happens again.
    • [win10] Dropping image file on open (new) document crashed VS
      • syllie
      6094
      @VectorStyler Looks good. Thanks.
    • Trace B/W drawing - Ignore background not working?
      • syllie
      4368
      @VectorStyler Looks good!
    • [win10] Shape effect (warp) -> Convert to mesh -> Crash
      • syllie
      4860
      Looks good! Thanks.
    • [win10] Unexpected behaviour viewing Transform Effect on shape
      • syllie
      5135
      Looks good! Thanks.
    • [win10] RMB context menu misbehaving
      • syllie
      4198
      Sofar this looks good. I'll let you know if it reoccurs. Thanks!
    • [win10] Node Tool does not honor movement constraint with Shift
      • syllie
      8347
      This is working now. Thanks!
    • Resize via panel not refreshing
      8085
      @Igull I keep this issue open and will find a solution somehow.
      Artboard Gets Automatically Created If An Object(s) is Selected
      • gotanidea
      4049
      @VectorStyler Thanks Admin
