    Rename Layer Object using Object Options Panel
    11 Posts 3 Posters 10.4k Views 3 Watching
      VectorStyler @Igull
      @Igull Added this to the backlog.
      • IgullI Offline
        Igull
        Neil
          VectorStyler @Igull
          @Igull Cannot replicate this here, tried both Mac and Windows.
          it might be that it has to do with the specific selected object, or the hierarchy.
          IgullI 1 Reply Last reply Reply Quote 0
          • IgullI Offline
            Igull @VectorStyler
            @VectorStyler said in Rename Layer Object using Object Options Panel:
            Have just revisited this today, the issue is still there - as you suggested, it may have something to do with the object - it was an imported PDF of a bit image (around 1Mb) and I see the same thing on a couple of other images on the workspace (also around 1Mb, they're not on the artboard if that makes a difference ??).
            I can mail the file if you wish.
            TIA
            Neil
              VectorStyler @Igull
              @Igull Email me the file and a small screenshot of the Layers panel highlighting the object that cannot be renamed.
              • IgullI Offline
                Igull @VectorStyler
                Mea culpa - the doughnut of the week award goes to me ☺
                If an object is locked in the layers panel, you can't rename it in the Object Options Panel - that kind of explains the "issue".
                Apologies for taking up the bandwidth, I wouldn't expect to be able to change anything if it was locked.
                I did ask if maybe a doughnut popup might be arranged that could fire up saying - Idiot - the item you are attempting to modify is locked 🙂
                Neil
                  Subpath @Igull
                  @Igull
                  just "happy accidents", bob ross 🙂
                    VectorStyler @Igull
                    @Igull This issue should be fixed in build 1.1.080
                    • IgullI Offline
                      Igull @VectorStyler
                      This still looks the same to me ? If the object is locked, the rename panel allows you to change the text of the name, but doesn't rename it (as before and as I would expect).
                      But there's no message or indication to say that the item is locked and can't be renamed ?
                      Neil
                        VectorStyler @Igull
                        @Igull said in Rename Layer Object using Object Options Panel:
                        This must be the cause.
