    • Splash screen problems
      2864
      @encart Added this to the backlog.
    • Multiple object scaling together move opposite
      3310
      @Boldline Replicated here also. This one seems to be a regression from one of the recent builds. As a workaround: turn off the "Direct Shape Transformation" in Preferences -> Editing Options 2.
      Selection Intersecting / Containing toggle
      • larsherold
      5222
      @larsherold Found the bug, it affects the Selection panel only. The option is activated, but it is only taken into use after opening a document (or closing and reopening the current one).
    • Groups made in "customize toolbar" panel do not show as extendable/retractable options in new toolbar
      4072
      @Boldline I open a bug on this one.
      Various units in Transform panel
      3811
      @Harry The only way for now is to just add a different unit name after the number, for example "10 pt" will set that field to use pt.
      Circle: changing its shape with the Shape editor tool
      8045
      @Pat , thanks Well, I'm sitting at a 40-inch screen with 1440 x 900 pixels. I like large screens with a slightly lower resolution when I'm editing vector graphics. Find it better for the eyes because of the thin lines. Get along with the panels so far, except for a few exceptions.
    • Stylus creates extra rectangle selection box
      2911
      seems to be a bug in VS 1.1.079 during the installation procedure
      2804
      @Subpath Got it. Similar issue has been also reported by others on Windows. I will try to replicate this.
      Making a symbol, unexpected results
      5607
      @b77 @VectorStyler Thanks. I've always selected the whole object with the select&move tool and it worked so far. I tried to reproduce this problem. I selected and grouped and made sure everything was grouped. With the move tool, I can then duplicate it (Alt-drag) and move it. I activated 'Transform stroke' in the 'Object option' sub-menu, resize the whole object and made it a symbol (Object Role). It appears well in the symbol panel. I use it with the repeater function and the object ends up disappearing from the Symbol panel and from the large object I used to repeat it (Ctrl-R doesn't help). I will continue to test all these steps with a new file from the beginning.
      Just before clicking yes on the updater, I accidentally modified the open document, and VS refuses to close.
      • Gremriel
      2666
      @Gremriel I will try to replicate this.
      Impossible to reuse an old file with .078
      13987
      @b77 I could replace the file with yours and copying in VS is working fine Thanks.
      This topic is deleted!
    • 3 colour-related bugs
      8394
      @encart Send me an example file with the color issues. I will try to replicate it here.
    • The units in the Transform panel change according to position
      2590
      @encart I guess it happens after you delete just part of 'mm' (plus the number), so the app is left (or stuck) with 'm' to use instead?
      Shape position in clipped text at wrong place
      2487
      @Subpath Looks like a bug, added it to the backlog.
    • Bug in 1.1.077 - Snapping icon is always inactive
      8787
      @VectorStyler said in Bug in 1.1.077 - Snapping icon is always inactive: @Ingolf The fix for this problem will be in the next build. Meanwhile, as a workaround: uncheck the "Active Item" checkbox for the folder containing the enable action (in the context panel customization). Thanks, that worked!
    • Cannot edit notes when objects are hidden
      2831
      @Ingolf Added this to the backlog.
    • Pen tool - Cusp nodes in smooth node mode
      4334
      @Ingolf Could not replicate this earlier. I will try again, with the new info.
    • "flip horizontally" button with option sends result way off screen
      4945
      @Boldline Well, one thing that could help is to find out what are the prerequisites for this to happen. For example: what other actions are taken before. Something preferably short that can be repeated just after starting the app and then replicates the issue. But I will also look into this from a different perspective. There is a lot of persistence happening in the VS UI and it could be that the flip change keeps some size / position from a previous flip.
    • Corner Fulcrum Bug ?
      26
      26
      35770
      @b77 said in Corner Fulcrum Bug ?: @VectorStyler If the next build will have changes related to all this, please explain the changes here when it's released. Before I forget: The only change that will be in the next build is that when a free path (not parametric shape) is scaled or rotated and the "Direct Shape Transformation" is enabled (already exists), then instead of adding a "nondestructive" transform to the object, it will just scale the path, leaving the corners "rounded".
