      Link File Command Opens Export Options & Other Bugs in v1.1.077
      • gotanidea
      10725
      @gotanidea This issue should be fixed in build 1.1.080
    • Large steps during Align Stroke scrolling with the mouse scroll wheel.
      3483
      @encart This issue should be fixed in build 1.1.080
    • File name passing during printing
      5658
      @Igull This issue should be fixed in build 1.1.080
    • changing live text with stroke causes erratic results
      3449
      @Boldline This issue should be fixed in build 1.1.080
    • Missing font warning not appearing
      4699
    • Tracing doesn't work
      3902
      Vectorstyler hangs using Bend Distortion after having used Outline Path tool (1.1.075 Win10)
      • Gremriel
      4451
      @Gremriel This issue should be fixed in build 1.1.080
      Merge not working correct
      • MajorTom
      5022
      @MajorTom This issue should be fixed in build 1.1.080
    • [win10] Brush selection preview for custom brush not working as expected
      • syllie
      4944
      @syllie I will try to replicate this
    • R
      System UI Font Access Error
      • richbyte
      4030
      R
      @VectorStyler Thank you.
    • [win10] Switching from Node Tool (A) to rectangle (J) does not work
      • syllie
      4197
      @syllie Yes, there are a few other single-key shortcuts when in shape editing mode — you can see them in the right-click menu.
      Crashes with blended and transformed objects
      7830
      @VectorStyler Thanks, it will take as long as it takes... I'll be patient and enthusiastic to use VS to the best to its full potential
    • [Win10] RMB context menu not dismissed with Esc
      • syllie
      2551
      @syllie Looks like a bug, added to the backlog.
    • Customizing Toolbox: Application Menu: name.name.toolbox.strokebrush
      • syllie
      2808
      @syllie Yes, found it. Will be fixed in the next build.
      Object - Transform: issue with the transformation centre
      2586
      @Pat Could be an undo/redo issue (used by Preview). I added this to the backlog and will try to fix it ASAP.
    • Example of bug that occurs after VS is used for a long session
      2975
      @Boldline Added this to the backlog. It will be difficult to replicate
    • Undo makes VS crash
      4237
      @VectorStyler You could be right, because I have worked a lot with symmetry using cloning and often ended up like in this demonstrated example.
    • Changing the tracking value between two characters becomes the default for new text objects.
      3356
      @encart Can be replicated here. Could a regression.
    • VS tries to save other unintended open files
      8348
      @Harry Got it!
    • Object Rotate Increment Fail
      7651
      @VectorStyler said in Object Rotate Increment Fail: @Igull Added this to the backlog, as a new feature. Neil
