      (Win beta 1.0.027) Zoom ALT keyboard doesn't zoom out
      • Jono
      3498
      That explains why it zooms in such a high amount. I should have read the manual! Thank you.
      (Win beta 1.0.027) Lag with previous beta files
      • Jono
      3437
      Hi, will do. I’m actually just off to work so I’m afraid it’ll be tomorrow (Thursday in UK) before I can do this.
      (Win beta 1.0.027) Clipped drop shadow when applied to scatter brush
      • Jono
      3936
      @Jono I can replicate this one, so no need for a file.
    • Moving an object to the top/bottom of the Layers panel does not scroll the list. 1.0.025 Win
      3783
      @encart The layers panel list should auto scroll when dragging objects, in the new build 1.0.027
    • V
      Toolbox Tool Icon “Hovering” pop-up descriptions/"tool tip" not showing/changing properly
      • Vector-Rock
      4539
      @Vector-Rock The tooltip problems of the toolbox are fixed in build 1.0.027
    • Properties Panel/ Size. Height value have to be preceded by a minus.
      4917
      @encart The height field in the properties panel should work now with top-down coordinate direction also.
    • Undoing a brush stroke makes previous stroke change size
      5354
      @Boldline The refresh issues caused by brush stroke changes (both undo and expand) has been fixed in build 1.0.027
    • Bring Forward/Backward Shortcut doesn't work with text
      3676
      @encart The bring forward (and other) while text is selected, shortcut issue has been fixed in build 1.0.027
      Can't draw Concentric Circles (Windows)
      • Gremriel
      9045
      @Gremriel The concentric circle drawing issue has been fixed in build 1.0.027.
      Object selection problems
      • Kyriakos
      8339
      @Kyriakos said in Object selection problems: Nice, this seems to fix the text issue. I take it this isn't the expected behaviour? It's not giving me the nodes in new documents irregardless of the setting. It looks like a bug. The corner handles should not be visible for the text. But I could not replicate here, even with the settings/workspace files. I keep this as an open issue in the backlog.
      [M1] App crashing when pasting-in image from Skype
      • Kyriakos
      5543
      @vectoradmin Just reporting that this seems to be fixed in the latest OS update.
    • V
      Build 1.0.026 RC3 (correction) for Mac (Intel) is missing Color Palette
      • Vector-Rock
      2656
      @Vector-Rock The Palette (maybe should have a different name) is available only when a document is open. It can be sometimes left there after a all documents are closed.
      Heavy flickering of nodes when using Corner Tool/Shape Tool
      • Gremriel
      6055
      @vectoradmin I turned off GPU distortion for Mesh and Distortion, and the flickering was gone. I then turned both options on again, and the flickering didn't occur anymore.
    • Stroke weight in appearance panel not changing incrementally
      4614
      @boldline. Yeah, that's why I started the topic on this originally as noted by @b77. It's cool that @vectoradmin has put both the "incremental Up/Down arrow icon adjustment scrolling" and a better "slider" icon on the backlog. I can see why it might take a while to implement. My recommendation was to have the Incremental Up/Down arrow icon adjustment scrolling control appear in every spot that currently has "sliders"- that's a lot of places- even preferences. While I do occasionally use the "slider" control, and am glad it is available, I really don't use it much. Would use "incremental" all the time, along with "direct numerical entry". @vectoradmin I actually find myself wishing that the drop down icon choice was more widely used. It's nice to get that very quick "live" visual update as you hover/zip down the presets.
      Wrong control sizes (macOS) in certain dialog boxes
      • Arde
      3922
      @vectoradmin Thanks. It is great that fixes can be addressed as directly as this. When not, I always feel that the code is beyond the reach of developers, and more or less module based so that fixes like these can only be expected along with framework/library updates.
    • Distortion of shapes when moving nodes 1.0.025 RC2 Win10
      3002
      @encart Got it. Will try to fix it in the next build. A workaround: select all nodes and convert them to cubic curves, by clicking the last icon from these icons in the context panel: TrueType (and some OpenType) fonts result in quadratic curves (typically not directly editable by other apps), but SVG has them so in VS they are editable. But there seems to be a bug here.
      Gradient mesh shape will persist for every other new shape created
      • Kyriakos
      4463
      @vectoradmin Works fine now, thanks. I noticed something else with it that might be a problem, after double-clicking inside your mesh to create a new node you need to reselect the newly created node in order to colour it, otherwise the entire shape gets filled and you cannot undo. So it might be better if newly created nodes are already selected so you can immediately adjust their colour without having to re-click them. *Forgot to add that after accidentally filling the shape with a solid colour it sometimes breaks and creates some weird vectors as such...
      Combining text with a shape does not work
      • Gremriel
      11104
      @Gremriel The new build 1.0.025 has some fixes regarding the text shape combination issues.
    • One-time error. Impossible to duplicate/ copy object in any way ( empty layer). App crashed.
      3190
      @encart I will try to replicate, there was a regression in duplication in version 1.0.022 and 23.
      Glyphs panel: glyph categories are not shown for certain fonts
      • Arde
      10136
      @vectoradmin said in Glyphs panel: glyph categories are not shown for certain fonts: @Arde In the Glyphs panel menu, the Unicode Blocks menu item has some options to reveal other blocks Wow, the features of this app are just incredible!
