Properties Panel/ Size. Height value have to be preceded by a minus.
Otherwise object's hight become less than 0,5mm
@encart I could not replicate this issue. Cannot even input negative values into the height field (should not be able).
@vectoradmin For me it is like this:
https://recordit.co/JTrt6oPJiE
Edit: I had this problem in previous build also.
@encart Got it! it is caused by top-down coordinate mode, will be fixed in the next build.
@encart The height field in the properties panel should work now with top-down coordinate direction also.
