@vectoradmin said in Win 10 - Select shortcuts not working:
Reselect repeats the last of these commands (instead of returning to the dropped selection).
If one of the Attribute commands was used, then reselect does not need a selection.
If one of the Similar commands was used, then reselect needs a selection to find the similar objects.
That isn't really "Reselect" then but rather "Repeat Last Selection".
But, for saving and recalling past selections, there is a Selections panel (Panels -> Editing). A bit more tedious, but it can save any number of selections, that can then be recalled in a single click.
Suggest building on this by automatically updating a (possibly hidden) saved selection at appropriate times then adding an actual "Reselect" command that restores that.
