    Stroke weight in appearance panel not changing incrementally
    4 Posts 4 Posters 5.6k Views 1 Watching
      I went to adjust the stroke weight of my path in the appearance panel and noticed when I click on the up arrow (or down arrow), the weight does not change. It makes the slider pop up and that can be used, but if I want to just quickly tap and have an incremental amount added, it does not do that.
      Here is the video
      Update: tried this in the stroke panel as well with the same result
      • b77B Offline
        b77 @Boldline
        @Boldline It might look similar to a group of two buttons, but it’s a single button that pops the slider.
        You can however click inside the field and scroll to increase/decrease the value, or use the Up/Down keyboard arrows. It’s been discussed here: https://www.vectorstyler.com/forum/topic/434/allow-for-incrementally-increasing-decreasing-unit-values-in-dialog-boxes-panels/10
          @Boldline There is an open issue in the backlog, to improve how these number inputs are working. including incremental scroll and better slider icons. But it will be a bit later.
          • V Offline
            Vector-Rock
            @boldline.
            Yeah, that's why I started the topic on this originally as noted by @b77.
            It's cool that @vectoradmin has put both the "incremental Up/Down arrow icon adjustment scrolling" and a better "slider" icon on the backlog.
            I can see why it might take a while to implement. My recommendation was to have the Incremental Up/Down arrow icon adjustment scrolling control appear in every spot that currently has "sliders"- that's a lot of places- even preferences.☺
            While I do occasionally use the "slider" control, and am glad it is available, I really don't use it much. Would use "incremental" all the time, along with "direct numerical entry".
            @vectoradmin
            I actually find myself wishing that the drop down icon choice was more widely used.
            It's nice to get that very quick "live" visual update as you hover/zip down the presets.
