      Variable fonts not yet supported on Windows version?
      • Arde
      11962
      @vectoradmin The latest build seems to linearly adjust both the width and the weight -- thanks!
    • Problem with interface while using graphic tablet.
      7796
      @encart I tested the drawing used pressure sensitivity. With the pencil tool, the context panel contains a "Pressure" drop down (on the left side), here the "Pressure" mode must be selected to use the table pressure. I used a Wacom Intuos tablet on Windows.
    • Issues with launching context menu.
      4124
      @encart Just tested this, and it can be replicated. Will be fixed in the next build. A workaround till then is to move the mouse a bit away (to the left) before releasing, so it does not fall inside the menu. I think I should time that release so it does not close immediately, but can still be closed on first release.
    • Some Arc Warps not working
      6593
      @Boldline This should be fixed in the new build (1.0.022).
    • Strange behaviour of corner radius handlers.
      7572
      @encart This should be fixed in the new build (1.0.022).
    • Saving workspace settings to file without extension.
      4891
    • Editing corners. Impossible to select corner node after rounding.
      4234
      (Windows beta 1.0.021) View > Full Screen (no way back)
      • Jono
      3967
      @Jono The menu is kept on now in full screen mode, in the new build (1.0.022).
      (Win beta 1.0.021) Glyphs panel has no scroll bar
      • Jono
      4954
      @Jono This should be fixed in the new build (1.0.022), and there were some performance issues with large CJK fonts also, fixed that too.
      (Win beta 1.0.021) Selecting options from menus
      • Jono
      4564
      @Jono This should be fixed in the new build (1.0.022).
      Blend mode of the stroke not effective
      • Arde
      3307
      @Arde This is fixed in the new build (1.0.022).
      Artboard list is not updated
      • Arde
      8324
      Possible bug (pattern as zero width stroke)
      • Arde
      4090
      Cannot select shape in isolation mode
      • Kyriakos
      9146
      @Kyriakos Added an extra label to indicate that it is isolated in the content of the object, in the new build (1.0.022)
    • Broken angle slider and value field in Properties panel.
      5135
      @encart The angle slider may jump from max (360 or 180) to 0 if that is its interval. For other (non angle) sliders this could be a bug.
      (Win beta 1.0.021) Rectangle corner rounding only from edit panel
      • Jono
      4498
      @Jono @vectoradmin I don't have your problem, but yesterday I had a problem with subtracting and adding shapes. These were two normal circles converted to curves, but the bolean operations were inactive in every way. After that I copied the shapes into the new document and it worked fine. Sometimes I come across such situations, but I can't relate them to anything. They happen suddenly and gone after restart.
    • Problem with boolean add operation.
      4139
      @vectoradmin I used Times New Roman.
      Opacity in Color panel has effect on both fill and stroke
      • Arde
      6698
      @Arde OK, I agree — can't say it doesn't make sense to be that way. However, I would still move the Transparency slider from being the last in the list/stack in the Appearance panel to be at the top, "glued" under the name of the object, so the user makes the connection that it changes the opacity of the object, not of the fill.
      Issues with bleeds
      • Arde
      7088
      @861475_VctSt Got it!
    • Layers Not visible in Layers panel
      3447
      @Boldline I added this to the backlog. Could closing and reopening the layers panel help?
