    • Shape Builder tool creates unwanted oval at bottom of square shape creation
      3653
      @Boldline I'm happy to help
    • Brush color turns to white despite it not being white initially or in color panel
      2721
      @Boldline Could be an issue with the brush not stretching correctly over shape. Send me the file containing the white brush.
      Bug in Layers panel
      • Petar_MK
      7395
      OK. Sure I will. Thanks.
      It seems i have a "Save As" problem.
      7484
      @vectoradmin Great, thanks. Intalled and tested, seems every case work fine now.
    • Layer / object must be highlighted to be hidden / visible
      9323
      Verified as fixed!
    • Node handles moves node bug (beta 1.1)
      15161
      Verified fixed!
    • Buggy behaviour when selecting line width for a circle (dashed line)
      • ambros
      5341
      @vectoradmin brilliant. Glad you managed to isolate. Thanks
    • Weird Issues with paper size
      • ambros
      4661
      @vectoradmin that’s great news- very reactive- thank you
      Unintentional behavior of VS Application window
      5946
      @vectoradmin thanks for the fix, have had it figure out allready that it works now , in the beta
    • Text in Non Displayable Font is Not able to be switched
      3831
      @Boldline This issue should be fixed in the new build 1.1.002 (beta)
    • Preferences to set eraser indicator color do not seem to work
      3245
      Cutting and pasting blend has different name
      • Jono
      3214
      @Jono This issue should be fixed in the new build 1.1.002 (beta)
    • Copied and pasted jpeg from the internet not displaying properly.
      4034
    • Draw inside option missing
      11453
      @Ingolf This issue should be fixed in the new build 1.1.002 (beta)
    • Option - double click doesn't work in shape editor mode
      3353
      Language menu is unusable
      • ash-f
      3665
      @ash-f This issue should be fixed in the new build 1.1.002 (beta)
    • Files saved after VS Beta 1.1 update have no content.
      • Qode5
      11967
      @Qode5 Could not replicate this issue. Let me know if it still occurs (beta 1.1.002)
    • Beta 1.1 - double clicking in text mode should not activate node editing mode
      10412
    • Offset Profile Width Display Not Keeping up with Selection
      3199
    • Text not scaling for me
      5577
      @Boldline This may be related to the spacebar issue, and it is fixed in 1.1.002
