      Insert graphic from clipboard
      • freggern
      4098
      @freggern This issue should be fixed in the new build 1.1.002 (beta)
      Clipped blend lines disappearing
      • William Kansepa
      3847
      @William-Kansepa This issue should be fixed in the new build 1.1.002 (beta)
    • VS crashes while using Alt-key to duplicate.
      4043
      @encart This issue should be fixed in the new build 1.1.002 (beta)
      Reference point in Transform dialog not honored in "Each" mode
      • Arde
      3145
      @Arde This issue should be fixed in the new build 1.1.002 (beta)
    • Win 10 - Dual Screens Bug - Switching Maximized VectorStyler Window Using WIN + SHIFT + Left or Right Arrow key
      • Victor Vector
      4029
      @Victor-Vector This issue should be fixed in the new build 1.1.002 (beta)
    • Option key to flip pull down guide not working for me
      3681
      @Boldline This issue should be fixed in the new build 1.1.002 (beta)
    • Paste Below Not Working
      4106
      @Boldline Paste Below should also work if nothing is selected (from build 1.1.002 beta)
    • Artboard disappeared right after pasting vector from Illustrator
      4354
    • Imported vectors revert to initial size when copied inside VS
      3611
    • Node handle jumps and locks when shift is held
      3942
      @Boldline Checked the file, it seems that the node next to the line is set to be symmetric. Control points of symmetric nodes next to a line will have fixed positions. To fix this, set the node type to smooth or cusp.
    • New Brush Preset Panel empty
      7643
      @vectoradmin I just emailed you back - it seems when I opened the AI brush set file in VS and it was not visible - when I closed out VS and logged out, but then logged back in, the brushes were suddenly visible in the brush preset panel! I sent you the workspace.xml file just in case it helps with anything
    • The text whose size we set with Alt/Option is light-gray by default.
      2696
      @encart Yes, it is the default fill color. Default color can be set from the color panel.
    • [Beta 1.1] [Pen Tool] Pressing Alt while dragging does not create a corner point.
      5291
      @encart yes, the key has been disabled for this purpose, and this is a regression. will be fixed in the next build.
    • Beta 1.1 - Shortcut (Control+Shift+K) to find and highlight selected object in the Layers panel
      5507
      @vectoradmin said in Beta 1.1 - Shortcut (Control+Shift+K) to find and highlight selected object in the Layers panel: @Ingolf It could be again a settings conflict issue from the previous version. Try resetting the app (Shift+Option+Command) Worked
      My mouse wheel no longer works - in VS Beta 1.1
      10193
      @vectoradmin Problem solved. Scrolling with the mouse wheel seems to work now. I decided to reinstall VectorStyler. Was going to install the program to a different folder anyway. And after the reinstallation the mouse wheel scrolling works as usual.
    • Free floating toolbox aligns to bottom at every program start
      4290
      Fixed in beta 1.1
    • Export of lines changes colors
      6473
      Fixed in first beta
    • Using keyboard shortcut to "Save As" Causes Immediate Crash of VS
      28
      28
      44282
      @Jono I think we've figured out the issue for now. thanks for your help!
    • Union issues
      5149
      @Ingolf Got the file: and yes the issue here is that an expand stroke will be needed first. I'm not sure how this could be handled better, I will consider comments by @b77 but at the end of the day, if it is just some shapes that the user wants to merge, it cannot be blocked based on some attributes.
    • Normalize Winding does not seem to work
      4836
      @Boldline Leave that setting on (BTW: I have to fix that name of the settings). The information is the direction of the various parts of the path. In this example there are 3 paths: using even-odd fill rule. winding mode rule, both paths are clockwise (merged with Normalize Winding). winding rule, one path is clockwise, the other is counterclockwise (stays the same with Normalize Winding). 0_1638533723544_windingmode.vstyler 1. using even-odd fill rule. (it should be the same as in AI).
