    • Layer panel shouldn't disable common keyboard shortcuts
      8446
      @Ingolf This issue should be fixed in the latest build
    • The parts of text becomes invisible after using Break Apart.
      4004
      @encart @b77 This problem should be fixed in the latest build
    • Deleting text automatically moves text cursor to the far left side
      10326
      @Boldline This problem should be fixed in the latest build.
    • Can't scale individual objects after VS 1.1.002 Beta update.
      • Qode5
      5858
      @Qode5 This problem should be fixed in the latest build, let me know if it still occurs.
      Pen tool sticking when attempting fine movements
      • Jono
      4914
      @Jono There have been some improvement in the Pen tool and how it handles snapping in build 1.1.008
    • When Grouping fails occasionally....
      2580
      @Boldline Let me know if there are still issues of this kind when grouping .
      Symbol selection highlight not clearing after deleting object used to create symbol
      • Jono
      3600
      @Jono This problem should be fixed in build 1.1.008
    • Path Brush tool seems to be acting like an eraser at times
      3795
      @Boldline This problem should be fixed in build 1.1.008 (part of the larger merge, union, divide fixes).
    • Selecting all objects on a layer using the circle in the Layers panel does not allow for immediate keyboard arrow editing
      4398
    • Offset Path affects neighboring shapes
      4458
    • Repeater issue with expanded text
      3946
    • Two words cut off in Crash Report Text
      2462
    • Grouped blends that have not been expanded, are not able to be expanded together at the same time.
      3429
    • [Repeater][Paste Inside] Shifted Expanding position, Shifted pasting position.
      4777
      @encart These problems should be fixed in build 1.1.008
    • Breaking rotated text returns to the horizontal position.
      3164
      @encart This problem should be fixed in build 1.1.008
      Missing letter in repeater panel style option
      • Jono
      3611
    • Manual resizing of the font disables setting the size of the font using the Alt key.
      4125
    • [Appearance Panel]Multiple items are highlighted in panel's menu
      2407
      @encart Can be replicated! I will try to fix it.
    • Two Layers Panels
      • Petar_MK
      4126
      Thank you.
      Tools, Color panel
      • Petar_MK
      5374
      Thank you.
