    • Scaling object with transparency mask.
      • Qode5
      4152
      @Qode5 One issue that happened here is that when scaling some shapes (rectangle or ellipse) the object is not scaled, only the shape size is adjusted, which blocks the mask scaling. This is fixed bow in build 1.1.002, by always scaling the object if it has a transparency mask.
    • Top Layer View Disappears in Dartboard when object below is moved with stylus/mouse
      4508
      @Boldline This issue should be fixed in the new build 1.1.002 (beta)
    • X for toggle fill and stroke does not work in shape editor mode
      12642
      @Ingolf Changed the shortcuts to have X always for the color swap.
    • pen tool leaves odd starting node with handle
      4083
      @Boldline This issue should be fixed in the new build 1.1.002 (beta) For existing paths, adjusting the control point at the starting node will fix the issue.
      Importing vertical text from Illustrator file not usable
      • ash-f
      5351
      @ash-f This issue should be fixed in the new build 1.1.002 (beta)
    • "Inside Last" not working?
      3084
    • Preferences>Document Files>New Template wants to save a file?
      3174
    • Some features are not available in shape editor mode
      4119
      @Ingolf Expand stroke is active in shape editor mode from build 1.1.002
    • Unable to convert stroke to object or expand it
      3783
      @Ingolf This issue should be fixed in the new build 1.1.002 (beta)
    • Custom toolboxes - vertical setting
      3819
    • Knife tool - issues and questions
      4858
    • Title Corrections not Updating in Font Manager
      3257
    • SVG export of path - bug or feature
      3838
    • Cannot always undo an ungroup command
      2772
      @Boldline This issue should be fixed in the new build 1.1.002 (beta) EDIT: undo may still be an issue on existing files, where the wrong undo history is saved.
    • Difficulties selecting a shape under another
      5082
    • Is this a group or bug?
      8592
    • Export issues
      9706
    • Poltergeist border
      3560
    • Mouse wheel zoom shortcut reversed
      4653
      Garbled images on import
      • William Kansepa
      3474
      @William-Kansepa This issue should be fixed in the new build 1.1.002 (beta)
