    • select>select by style>fill content only selects what is visible on screen -not entire artboard
      7733
      @b77 I agree with you that it should not be buried in the preferences, especially considering there are several great selection options as you listed in your mock-up. "Current artboard, current layer, current selection, viewing area, are all great options for this. If they are easily accessible, I would use each of them at different times in my work, knowing now that they are available/could be available. Sometimes the select list feels a little cumbersome and lengthy. There are certain select options I use a lot more than others. Would it also make sense to have the select options available at the top right? Just throwing the idea out there.
    • Snapping Does not work if Shift is held down
      3893
      @vectoradmin I just emailed you those files.
    • Pressing Enter key after typing the font's name does not select the highlighted font
      2773
      @encart Yes, the enter issue can be replicated on Mac also. I will check if the external fonts can have preview.
    • The Align/Transform/other panels do not revert to panel form when placed in the bottom bar.
      2931
      @encart Drag the panel to the right margin so that a vertical blue highlight is shown, and dock it there.
    • Brush size keeps reverting to .44 width for some reason
      3134
      @vectoradmin Restarting VS fixed the issue with the line width reverting back each time I changed it. However, I still get the brush tool defaulting to the second brush in the pulldown list even when I've chosen the top one for example. This does not happen if I chose other brushes in that pulldown - the brush does not revert and satays with what I selected - which is what I would also expect when I choose the very top simple brush
    • Windows - isolated mode greyed out after one use
      9466
      @vectoradmin Yes, I know, it was disabled here for some reason I don't remember on the Windows computer. But the feature itself ...
    • Is Null in rotation to be a layer color indicator?
      3015
      @vectoradmin if I see it happen again I will certainly send.
    • Cannot adjust spacing between to letters with Option key
      4497
      @Ingolf Seems that in macOS the Alt+Arrow keys are used to jump between words in the text editing mode. This is a standard macOS thing. Try Control+Alt+Comma / Period to decrease / increase tracking in the editor.
    • Magic Wand/ Box Selection/Lasso/Polygonal toolbox stays dark and interferes with other tools
      3463
      @b77 ok I guess I had not given it that level of thought or maybe I was thrown off because I was trying to switch from the brush tool to the magic wand and it was continuing to make the brush strokes when I thought it would become a magic wand. I did not put two and two together that I needed to use it as an extension of the transform tool. thanks for helping me think that through
      Change filling
      • freggern
      5376
      @b77 Ok, I understand. Thanks for clarify! @vectoradmin The 2nd problem is fixed!
      Edit path on a "add vertical text on path" change flow direction
      • freggern
      4141
      thx, tested!
      Resize grid shape does not work correct
      • freggern
      4126
      thx, tested!
      SVG compatibility issue
      • ash-f
      13714
      thx, tested!
    • Non-exportable layers (layer options) are exported
      4692
      @vectoradmin said in Non-exportable layers (layer options) are exported: @Ingolf This problem should be fixed in build 1.1.008 (both export and printing). Yes, both fixes verified.
    • Double clicking stroke color changes it
      3636
      Fixed!
    • 1.1.005 - boolean operations icons too small
      5782
      @vectoradmin said in 1.1.005 - boolean operations icons too small: @Ingolf Could not replicate this one so far. Let me know if it is still an issue in the new build (may need a workspace / settings reset). Fiddled with some scaling settings and now it looks fine again - thank you for your time
    • New gradient should not be created on single click
      4089
      Indeed fixed, thanks!
    • Draw inside issues build 1.1.002 (beta)
      3897
      Verified as fixed!
    • Alignment Panel Pulldown Seems fixed now
      3612
      @vectoradmin said in Alignment Panel Pulldown Seems fixed now: @Boldline Yes, if it has been resized before then the next time is opened, it will keep the size. It was not staying at the corrected size prior to this.... (or maybe it was fixed in the prior build and I did not check?) Regardless, it is not doing wonky things when I try to compress that space anymore and each time I open it now, it's working as it should - so thank you!
      Rows and Columns
      • Petar_MK
      3923
      Thank you.
