    3. VectorStyler 1.2 beta
      Adding action to application toolbox crops the first column of icons
      4013
      @VectorStyler said in Adding action to application toolbox crops the first column of icons: It Could be caused by that single tool group at the bottom Could be, because after adding second action to this tool group, toolbox isn't cropped anymore
      Panel gets narrower
      6835
      @Pat I will try to replicate this still. There is always some other condition for these.
      Artboard "Show Size in Label" option changes artboards' dimensions
      3332
      @Harry Yes, seems that the artboards retained their format (should not) after drawing. Will be fixed ASAP
    • Extended crosshairs still an issue in the new beta build
      3395
      @VectorStyler I didn't mind the crosshairs actually, just didn't want them to extend far beyond the size of the circle. Having it be an empty circle might be ok too
    • update 1.2.006
      • VectorStyler
      4907
      @VectorStyler There was an entry for VS 1.2.006 in the Windows App Uninstaller. I uninstalled both betas, downloaded it again, and the beta works now.
      Shape effect, option panel
      24
      24
      33659
      @Pat said in Shape effect, option panel: the strokes suddenly disappeared and it was impossible to get them back. I will try to replicate this.
      Little panel icon displaying options
      2537
      @Pat Can be replicated. Seems to work only of the panel is not iconified.
      Select-menu out of line and can't find customize in view-menu
      • FastVector
      9969
      @Harry Thanks for your reply. 100% scaling or the mousewheel helped me for now to solve the problem with the 'customize' menu.
      Search next/previous options for search bars
      2547
      @Harry Thanks for the suggestion. I added this to the backlog.
    • Tool Indicator setting revert to same Shape
      • Ayo
      4283
      @Ayo Found the root cause of this issue, fix will be in the next build.
    • Textframe option do not work.
      5814
      @VectorStyler I see. I closed the Appearance panel and it worked. It's a bug.
      Pattern - some issues (or not)?
      4560
      @Pat said in Pattern - some issues (or not)?: @VectorStyler I've sent you the file Got it, thanks!
    • Unable to use the rounded corners tool
      8554
      @Boldline This issue can be replicated on MacOS Sonoma. It is a compatibility issue with the new OS, I will try to have this fix in the next build.
    • Duplicate by option + drag
      3834
      @VectorStyler Thanks. I was able to solve it. Settings > Nudgig was set to Reference. I may have unintentionally changed it sometime ago.
    • toolbox settings and locks for panels do not seem to be working
      5061
      @Boldline Tested, and works here also. Look into the user settings folder (Help -> Reveal Workspace Folder), if any of the files change after setting a new toolbox and exiting. Could be some other customization or workspace issue.
      There seems to be an issue with the Contour
      • Li Xiao
      4701
      @VectorStyler This bug has been fixed. Thank you.
      About the two bugs related to selection
      • Li Xiao
      7628
      @VectorStyler two bugs has been fixed. Thank you.
      Entering license key does not work.
      • Gremriel
      3368
      Thanks, uninstalling everything and re-installing fixed it.
    • Drawing Place Icons
      • Ayo
      4562
      @Ayo it might be that the draw inside icon was not exported correctly. I will check this later.
    • Restored node size in settings
      • Ayo
      2588
      @Ayo said in Restored node size in settings: Still can not set 'Transform Selection Node' node size to small (or large) rectangle. Remains medium. This is probably a different bug, I will try to find out what causes this.
