    3. VectorStyler 1.2 beta
      Split Object Shape on gradients - a bug?
      2421
      @Harry Not a bug. Currently the gradient is aligned to the object shape. I will try to improve this in the future.
      Suggestion: could numeric values in ALL fields be changed by the mouse wheel?
      2269
      @Harry context panel restricted by design. CMYK, HSB etc. values in color panel I have to check why this happens (could be also by design to restrict accidental changes).
      Stroke and Brushes panel options suggest a flyout menu with "play buttons" triangles.
      2411
      @Harry Replicated on Windows. It should not show these if there are no condition variables defined, can be ignored. Will be fixed ASAP.
    • beta 1.2.003 update
      • VectorStyler
      8591
      @Harry said in beta 1.2.003 update: In the profile editor view, it doesn't work at all. Replicated on Windows. I will fix this ASAP. As a workaround, drag the node out of the profile area to the left or right to delete.
    • Trouble with Snapping Icons
      • Ayo
      3106
      @Ayo cool, like them
      Pen tool icon/pointer
      3291
      @VectorStyler this will be difficult because when I click outside the VS workspace, I get the correct icon (which may disappear but always comes back)... I mentioned this issue because I thought it was permanent but it ends up working... so, weak prority to that
    • Did the brush width indicator change? I don't see a difference
      10914
      ok maybe I'm all set - I've updated the build since then and the icon for the path brush and eraser are both the current circle with brush inside and no longer the elongated cross hairs. Maybe I need to play around with it more but the two settings do not seem as different anymore from one another. I will test it more and get back to you
    • Serif Font while font selector says Arial
      • Ayo
      2425
      @Ayo Added this to the backlog.
      Contour stroke: bug?
      3057
      @VectorStyler I have already forwarded the file to you previously if you want to test it
    • Artboard Label Settings
      • Ayo
      5625
      Suggest putting the options in tabs on the right side - "Sizing", "Appearance", "Artboard Label", "Slice Label" perhaps? As long as there are only a few, logically organized tabs in a section that is still a logical and accessible way to organize these. Just need to be careful that it doesn't get out of control and lead to one of the three cardinal sins of tabbing: scrolling tabs, multiple rows of tabs or tabs within tabs.
      after installed beta 1.2004, 1.2002 still there
      3127
      @VectorStyler The thing is that it wasn't installed in a different folder. But as always in the Vectorstyler folder. But it's not a big problem. Just wanted to report it.
      New release - doesn't install
      7791
      Yes indeed, I had also allowed the "repair" of VectorStyler the first time not knowing what to do, and the complete installation succeeded after the fix of the beta version.
    • Should the live text blue line extend beyond the word?
      3849
      @Boldline @b77 I opened a bug on this one.
    • Number Editing issue
      • Ayo
      3510
      @Ayo said in Number Editing issue: Checked it again and it works! Don't get it. Could be that after opening the slider popover, it does not react to the first click.
    • Pencil tool keeps selection longer than necessary
      2634
      @Boldline Yes, this is a "highlight" indicator for shape drawing. It shows that those objects are still selected.
      Scaling objects
      • Kumr
      2477
      @Kumr thanks for reporting this. it can be replicated here also. it is caused by the large corner size at small rectangle size. I opened a bug on this one.
    • Transform (rotate) in Text Editor reference point
      • Ayo
      5210
      @Ayo said in Transform (rotate) in Text Editor reference point: copy/paste from webpage into frame There might be something here. I have to replicate this.
      Node tool on shape adjustment crashes VS
      9485
      @VectorStyler Grouping "solved" the issue
    • Lorem Disabled
      • Ayo
      4521
      @Ayo As a workaround for now: it requires a second click.
    • Improvement is poorly noticed if the problem no longer exists
      • Ayo
      3151
      @VectorStyler Yes
