    3. VectorStyler 1.2 beta
      Issue with the Shape builder tool
      5974
      @VectorStyler File sent. Two rectangles induce the issue (showed by arrows)
    • Setting the font size by dragging the mouse does not work.
      5096
      @encart Pressing Alt first and then pressing+dragging the mouse works here.
    • Editing vector mask inside transform>mask>drawing has location paste discrepancy
      2944
      Old problem with long paths is back in 1.2
      5526
      @Boldline said in Old problem with long paths is back in 1.2: @VectorStyler is it worth keeping your overall mode as an option? I think it might be. In some cases it could be important to see the precise shape of the erased area. Same goes for the path brush.
      Issue with the Blend panel
      6620
      @Pat I opened a bug on this one.
      Issue with stroke profile
      7090
      @VectorStyler You can try with the file I sent you.
      Issue with offset?
      4219
      @VectorStyler I've sent you the file with this specific object
    • UI, Theme
      5190
      @861475_VctSt I will review "Flat Dark".
      Gradient panel: not visible
      6332
      @VectorStyler It is fine now, I can display or hide the panel.
    • Regression
      4271
      @861475_VctSt I can replicate the issue. It is only in the beta, (1.1.110 does not have this regression). The earlier fix was done in the resources of the 1.1 fork only and forgot to check that in to 1.2 also. Fix will be in the next build
      Blend panel
      3063
      @Pat Will fix this ASAP.
    • JIS paper size
      3022
      Paragraph styles
      4467
      @VectorStyler file sent. Thanks
      Artboard layout - issue with snapping to guides
      3546
      @Pat Got the file, and opened a bug on this one.
    • Horizontal orange temporary guide line when moving objects, the horizontal line seems thinner than the others
      5333
      @Boldline I cannot replicate this here on retina.
    • Is resetting the workspace to default supposed to also set the settings to default?
      4442
      @Boldline I will test this, normally it should not reset the settings.
    • Could custom shape applied to erase tool also work when cursor is moving?
      2778
      @Boldline No, only for click erase and when holding Option(Alt) key to start erasing.
    • Add an option to shrink the panels to JUST the icons themselves? sans words?
      4368
      @Boldline It seems that the issue occurs only when the panels are docked.
    • Add option to font manager to add existing live fonts in document to document level save
      5048
      @Boldline said in Add option to font manager to add existing live fonts in document to document level save: what does VS do currently when it opens a saved file that has live fonts within? Yes, it scans the fonts from the document. This is OK to do once at startup. But as the document changes it will need to do again. It is not enough to just remember the font changes. The problem is that it will not know if a font change overwrites some other font or it is a new font.
    • Shrinking panels to icons does not always place the panels flush to the right side
      3493
      @Boldline yes, there are some issues when the panels are docked.
