There seems to be an issue with the Contour
There is an extra portion appearing in the middle.
Offset Path also has the same issue.
0_1697992689330_Contour.vstyler
https://youtu.be/dqDavveZoAg
@Li-Xiao Thanks for reporting this. It can be replicated here also. I will try to fix this as soon as possible.
The inside offset of 50 is too much for this shape. One way to get around this is to uncheck the Symmetric Offset option in the Contour panel menu, to have only outside contour.
@VectorStyler There are a new issues. When the fill color is set to white or none, only one line is displayed after applying contour. In the outline preview mode, all lines are visible. Expand the contour effect, when attempting to select a new width for the invisible lines after expanding, the program crashes.
@Li-Xiao Openeded a bug on this one. Seems to be related to another regression with the Blend.
@VectorStyler This bug has been fixed. Thank you.
