    3. VectorStyler 1.2 beta
    • Joining objects with path brush causes other objects to disappear
      4598
      @Harry said in Joining objects with path brush causes other objects to disappear: Creating loops with the stylus and Path Brush Tool results in unwanted fills (which do not disappear after pressing the Esc key) - this could be related. Video Yes, this is also a bug with the path brush tool.
      There are some issues with the Displacement
      • Li Xiao
      6163
      @VectorStyler Thank you. In practical use, will weigh the pros and cons, but having the ability to use it is much better than not being able to use it at all.
    • unable to get the kind of precision I need with the slide feature in offset path
      3105
      @Boldline In Settings -> Decimal Widths what is the value at "Inch Decimals"? Try increasing it (set to 3).
    • Eraser/Path Brush defaults back to "Pressure" setting when you switch away
      4594
      @VectorStyler just emailed you those files you requested. Let me know if you need anything else. i hope you can replicate it. Let me know if you think a screen video would be of help
    • Stroke reapplies itself even when removed prior when using pencil tool
      2292
      Issue with workspaces
      3830
      @Pat said in Issue with workspaces: I suppose that I have again to delete some files in the resources folder ? Try deleting all files in resources folder (without VS running). There is one bug in the "reset default" of both workspace and settings that might cause some issues, the fix for this will be in the next build. But it is not related to the toolbox.
      Moving layers (layers panel) "removes" shape effects
      5542
      @VectorStyler yes, that could be this... Now I think I always activate the history.
    • Stroke and fill in the contextual menu are not displaying information
      5203
      @Boldline A temporary workaround: select the "Color" mode from the top-right drop down of that popover.
      Issue adapting the size of the panels
      2841
      @VectorStyler perhaps to help: adjusting the width of the innermost column can be done by clicking on the top (see image). If you click and drag below, the width of the other (more external) column is modified (and the width of the innermost column remains unchanged). Edit: well... it doesn't work 100% either, but once in a while it does.
    • Restoring iconified panel not working, also width changes
      • syllie
      3132
      @syllie Yes, this can be replicated on windows. It occurs for docked, iconified panels. As a workaround: try clicking as much as possible to the left side of the icon (close to the double line). I will fix this in the next build.
    • Settings not applied or remembered
      2758
      @VectorStyler said in Settings not applied or remembered: Exit the app, and remove these (or back them up if you have important customization), and then restart the app with (will have the default workspace). Yes that worked
      Document setup & Guidelines
      5160
      @Pat said in Document setup & Guidelines: Here another view, with the canvas & artboard panel: I will try to replicate this issue. It could be related to the recent (last build) changes on how the artboard options are edited.
    • beta 1.2.007
      • VectorStyler
      1878
    • 'Layer from group' and 'Release to layers' don't seem to work
      • Ayo
      4131
      @Ayo said in 'Layer from group' and 'Release to layers' don't seem to work: Maybe better tooltip? Yes
    • Toolbox behavior beta 6, macOS
      2207
      @Ingolf Somhow this could be a similar issue as the one in https://www.vectorstyler.com/forum/topic/3808/settings-not-applied-or-remembered Here I can dock the toolbox both on the left and right, next to panels correctly. For some reason the workspace is not handled correctly. Exit the app, remove the settings and workspace files and restart.
      Panels getting wider
      • FastVector
      3092
      @FastVector I will try to replicate this. One thing about iconified panels: these can still be resized, with the text showing if the size is large enough. But by default, it should display only the icon.
      Docked Panels are cut off on the right side
      • Gremriel
      2420
      After a restart, the panels are not cut off anymore. I still can't make the column wider, though (it works in 1.1.115). *edit I can make the column wider; there seems to be a substantial delay before I can do it when I hover the cursor over the divider.
      There is an issue with flipping repeater content
      • Li Xiao
      3554
      @VectorStyler Thanks. Fixed in 1.2.006
      Adding action to application toolbox crops the first column of icons
      3102
      @VectorStyler said in Adding action to application toolbox crops the first column of icons: It Could be caused by that single tool group at the bottom Could be, because after adding second action to this tool group, toolbox isn't cropped anymore
      Panel gets narrower
      5335
      @Pat I will try to replicate this still. There is always some other condition for these.
