update 1.2.006
VectorStyler beta 1.2.006 release notes
- General stability improvements.
- Improved MacOS Sonoma compatibility.
- Fixed a bug with the knife tool on complex shapes.
- Fixed a bug in SVG and PDF text importing.
- Fixed a regression in repeater.
- Changing object size inside flipped group should use the correct pivot point.
- Exclude in composite shape to be the same as the exclude operation.
- Paste appearance to an object with existing object style.
- Switching to gray-scale sliders should select a gray color.
- Scaling text containing a local baseline path.
- Improved paragraph style handling.
- Show all available backup files when opening the app.
- Allow scrolling of numbers in color fields.
- Show the outline of a text frame when using the Node tool.
- Added a preview option in shape view.
- Path editing in outline mode to preview the moved path.
- Expand symbols command to work inside groups also.
- Improved symbol spray and adjustment tools.
- Rasterize to use correct object size when distortion image effects are used.
- Option to preview vector brush settings from modal view.
- Better handling of images as masks inside vector brushes.
- Improved brush tip preview in eraser and path brush tools.
- Contour options to allow color mode selection.
- Select tool tip delay option without restarting the app.
- Better handing of snapping in shape drawing tools.
- Allow monochrome icons when customizing icons.
- Update color panel when color style of selected object changes.
- Fixed a bug in text frame option selection.
- Additional transform panel options for selecting stroke and effect transformation modes.
- Use the guideline options selected in artboard format of document setup.
- Better handling of blend objects inside tiling patterns.
- Set the length of a side for a polygon shape.
- Scatter brush to use the width profile for symbol scaling.
- Transform angle selection from the horizontal transform panel.
- Copy and paste objects between artboards should keep object position.
@VectorStyler said in update 1.2.006:
Forgot the hovering?
Not sure why I always have issues with upgrading VS on my Win11 machine.
If I open the .005 beta, I get a notification that a new version is available. I click yes to download and install. The install finishes, but when I double click the icon, it opens up the .005 version, and shows me the new version message again.
When I download the new version manually, and run that, I get a dialogue that gives me the choice of repair or remove. Choosing the repair option, the installer does something, but when I start the app again, it is still version .005 and the new version dialogue appears again.
A new folder is created in /Program Files/NumericPath/VectorStyler 1.2, which only contains 34mb of files, but no executable.
*edit
A third icon appeared on my desktop. When I doubleclick that, a UAC window appears (I think it's called UAC), which asks me if I want the .msi file to apply changes. When I click yes, I get a dialogue that tells me the "The feature you are trying to use is on a network source that is unavailable". It is not, it's on my C drive. When I click OK, it tells me the installation package is invalid. When I click cancel, I get an unrecoverable error message.*edit 2
The update from 114 to 115 works as expected. -
@Gremriel I did test the update on Windows for the beta. Not sure what could cause this.
There was an entry for VS 1.2.006 in the Windows App Uninstaller. I uninstalled both betas, downloaded it again, and the beta works now.
