    • Not able to access the rotate option from the corners of a shape
      8114
      @VectorStyler said in Not able to access the rotate option from the corners of a shape: nevertheless, this "more quirky as the work day progresses" part needs to be addressed by me. I will try to remember and share the quirky things that repeat over time One of the common things to go wonky as the VS session progresses in the day is the "flip horizontally" tool. I usually use it with the alt key shortcut to make a flipped copy of the selection. It will start placing the flipped version far off the artboard, usually to the far right or left side and I have to go search for it and bring it back to the main artboard (only using one artboard at the time). Refreshing VS and worst case restarting VS fixes this issue and it will return to keeping the flipped version nearby the original location again
      Copy from one file into the other does not work correct
      • MajorTom
      3662
      @VectorStyler got it. all the cloned shapes are missing.
    • R
      Distortion of Spirals and Polygonal Spirals
      • Raven
      4349
      @Raven This is by design. The problem is that trying to increase each side smoothly will result in uneven spacing.
      Can't transform multiple shapes that are the result of the shapebuilder tool (1.1.075, Win10)
      • Gremriel
      4999
      I don't have that file anymore (I thought I saved, but then my PC crashed for reasons unrelated to VS). I tried again, with a similar shape, and now it works as expected. If it happens again, I'll make sure to save the file.
      Pressing Spacebar Key After Changing Font Type & Deselecting a Text Will Open Font Type Dropdown
      • gotanidea
      3609
      @VectorStyler Yes, it happens to the font size field on the top bar as well. After changing the font size in the field by pressing Enter key, the font size field is still in focus. This makes us unable to press a hotkey to use the Pan View Tool. In my opinion, it would be better to stop the focus on any dropdown, button or field after we use it, as in Adobe software
    • Strange rectangle resize bug.
      6151
      @Igull said in Strange rectangle resize bug.: Just sent files Got it. I will try to replicate with these.
      Text Object's Tab Problems
      • gotanidea
      4004
      @Boldline Yes, triple-clicking in other text editors and Adobe Illustrator will select one line. I will edit my post
      windows Resizes
      2559
      @Jayanta-Das Added this to the backlog.
    • Tracking seems to reset before overall word tracking occurs
      2518
      Artwork with Gradient Mask Effect applied fail to export
      • William Kansepa
      2993
      Will do so. Thank you @VectorStyler!
      Transformed Stroke Option Automatically Scales Stroke Width
      • gotanidea
      7619
      @VectorStyler Thanks Admin. The Scale Strokes & Effects checkbox in Adobe Illustrator is essential for scaling a complex object that consists of various stroke widths
      Eraser shape
      2616
      @Harry This is a bug, and it can be replicated. Will be fixed ASAP.
    • Delay when moving items with keyboard arrows
      11810
      @VectorStyler ok I turned off the "Show Position in Ruler" , saved and closed and reopened the file itself and now it's working correctly.
    • T
      Three-finger drag, tap-to-click unreliable (macOS)
      • tudor
      25
      25
      37234
      @tudor said in Three-finger drag, tap-to-click unreliable (macOS): Now I've just updated VS on an M1 Mac mini and the bug is still present Does this problem with the trackpad still present?
    • splash screen says "restoring state" and freezes up
      3707
      @b77 @VectorStyler Thanks for your help. When I first tried to just roll back to Build 68, I still got the same issue with it stalling out on the splash screen with the message "restoring state" (crash report was sent at this point when I force-quit VS) Next I removed the settings.xml and workspace.xml files and then installed build 68 again and it worked properly with no issues or freezes. It then prompted me to upgrade to Build 71 and I was able to also do that successfully - so all is good again!
    • Not easy to activate the snapping options icon to adjust settings
      17971
      I was thinking about this as it relates to the potential future addition of a button to hide all panels and open menus to allow for unobscured full screen work. If that was added to the far right side, that would move the snap options button over to the left a little bit and might solve the issue I have with it now.
    • some AI files open off the artboard in VS
      2727
      @Boldline This is an issue in VS in the AI format import code. I will try to improve it, but this one is a bit difficult.
      Vertical and Horizontal Scaling Distorts Strokes
      • William Kansepa
      3507
      @VectorStyler I reset my preference settings and uniform stroke scaling with Transformed Stroke enabled is now working as expected. Perfect. Thank you so much.
    • Stroke width tool defaults to zero width using stylus
      4590
      @Boldline I'm posting here some finds I found while experimenting with the Width Tools a while ago. Maybe it is helpful for you or anybody else. See this Video here this is just a pic from the video with the Stroke Width Panel on the left
      • William Kansepa
      3957
      @VectorStyler This thread seems to be related to the similar issue I brought up here My request was for the shape tools to not perform this altered stroke effect because they are not technically a path tool (as far as I view it) - this does not change until convert to curves is applied. The shape tools are more like building blocks to creating more complex shapes
