    • Separate Path with Eraser Tool Broken
      5158
      @VectorStyler said in Separate Path with Eraser Tool Broken: @Igull This could be specific to some shape and eraser tool width. An example file and a recording might help. It would, but yet again another elusive issue - it's not doing it today with the same file and same size and setup (as always!) brush. It may be some sequence of events that breaks it. I'll be sure to try and remember what happened prior to it breaking. Obviously, a restart seems to fix it Thanks Neil
    • Shortcut to Transparency Grid doesn't work
      3244
      @Ingolf @b77 This is a duplicate shortcut problem, should assign a different shortcut for Transparency Grid.
      AI file compatibility
      • ash-f
      6329
      @ash-f said in AI file compatibility: What I thought strange under the object with blend effect may be the gradient I will try to fix the blend / mesh and warp issues.
    • Inconsistency when changing values in numeric fields with the scroll wheel + Shift/Ctrl
      3547
      @encart Added this to the backlog.
    • editing nodes on one side of design negatively affects nodes on opposite side
      14318
      @Boldline your welcome, its always also interesting for me
      Strange behavior of outline coloring mode in Color panel
      4346
      @Harry Got the file, I will try to replicate this.
    • Improving lag during panning
      5297
      @Boldline The issue with the background can be solved easily. The problem is that it is not always white, sometimes the canvas has this gray background and that might cause problems.
      Offset path: undesired elements
      7118
      ... but now I get this with the same settings. I stop for now.
    • Quirky minor issue in swatches panel
      3266
      @VectorStyler with this one I know I used a mouse. I first noticed it when I accidentally slipped the mouse cursor slightly just after right clicking the mouse to change the background swatch. It's not a major deal, it rarely happens but figured it was worth mentioning
    • Can't left click to select or move nodes.
      • Qode5
      7541
      @Qode5 I open a bug on this one and will try to replicate it.
      This topic is deleted!
      • gotanidea
      194
      Colour popup window: no more options
      3251
      @Pat Looks like the Noise mode is selected, but it should indicate that in the drop down.
      Revert to original statewith the history panel: yes or not quite ?
      4402
      @VectorStyler ok, will do
      Image Effects
      27
      27
      36558
      @VectorStyler Sorry I mean Offset to shadow and angle to control the direction of glow.
      Copy-paste the 1st object used for a blend &...
      3781
      @VectorStyler file sent.
      Shift modifier key smooth the corner
      7664
      @Jayanta-Das said in Shift modifier key smooth the corner: @Boldline I use Shift key to constrain the line 45°. ok that makes sense. Perhaps instead of turning it off by default it could be moved to a new modifier instead? I agree the shift makes more sense with constraining angles - muscle memory
      Panel resize
      2498
      @Jayanta-Das Added this to the backlog as bug.
    • 4 button dialogue popping up before VS freezes
      • VectorWhiz
      7447
      @VectorWhiz Was "Automatic Backup" turned off also? Meanwhile, I found the issue causing this in case of auto save.
    • Background objects still disappear when editing nodes above
      3973
      @VectorStyler terrific! glad for the other upcoming fix and this one as well. thanks!
      Mesh gradient editor: artefacts
      3552
      @Pat Yes, this can happen. I will try to improve this. Some of these self-overlapping cases are a bit difficult. For example, if a control (tangent) point is rotated too much, it may create some impossible cases.
