      Windows - Cannot snap resize the program
      • Mongeuse
      4560
      @Mongeuse This problem should be fixed in build 1.1.048
    • Text Menu > Text Shape/Frame Title Inconsistency
      • Victor Vector
      3451
      @Victor-Vector This problem should be fixed in build 1.1.048
    • Linked Greyscale Image issue (semi resolved)
      • Devil Dinosaur
      3323
      @Devil-Dinosaur This problem should be fixed in build 1.1.048
      Slider in the Shape Panel has no usable range
      3306
      @Subpath This problem should be fixed in build 1.1.048
      Minor issues with german umlauts "üäö...."
      23014
    • Text Frames copied with CRTL+D cause performance hit when text is edited.
      • Victor Vector
      7866
    • Panning with the mouse wheel breaks the path
      6934
      @encart This problem should be fixed in build 1.1.048
    • Transparency via keyboard stops working (.26)
      12155
      @Ingolf This problem should be fixed in build 1.1.048
    • Extra base lines appear when grouping multiple pieces of live text
      4991
      @Boldline This problem should be fixed in build 1.1.048
    • Anchor Point tool does not seem to work at all in build 26
      3089
      Issue in snapping.
      12520
    • Closing object while dragging - other node affected
      9918
    • Control + backspace deactivates input mode
      3454
    • Codepage mismatch in taskbar
      5627
    • N
      Available shape style overrides list not showing any styles ( accumulated )
      • Nils
      3877
      @Nils This problem should be fixed in build 1.1.048
    • N
      Changing member of grouped clone original hides clones ( accumulated )
      • Nils
      3731
    • N
      Symbol instance goes transparent when switching canvases ( accumulated )
      • Nils
      6306
    • N
      Canvas role "Object style" doesn't work, others do ( accumulated )
      • Nils
      3597
    • N
      Change to applied shape style override doesn't propagate ( accumulated )
      • Nils
      3630
      Font dropdown list glitch (Windows)
      • Gremriel
      18253
      @Gremriel Yes, I was able to replicate the issue by changing the UI scaling settings in the preferences.
