    • Edit Cap, Edit Arrow - "Space" field does not recognize a typed negative value
      • Victor Vector
      4404
      @Victor-Vector This problem should be fixed in 1.1.048
    • Object partially masked doesn't render at export
      • Devil Dinosaur
      5527
      @Devil-Dinosaur This problem should be fixed in 1.1.048
    • Toggling the Transform panel from the panels menu hides or moves contextual menu bar instead
      4095
      @Boldline This problem should be fixed in 1.1.048
    • Cusp Retraction shortcut causes strange results
      4851
    • Polish diacritical marks require double press
      4876
      @encart This problem should be fixed in 1.1.048
    • Sometimes the shape tool does not create a shape on the canvas
      2728
      @Boldline If the problem still persists?
    • When tracing a bitmap with image effects applied brightness goes up and down
      3595
      @Ingolf This problem should be fixed in 1.1.048
    • Draw above bug
      4312
    • Image Effects Filter - "Opacity Values and Mask" Drop-down UI glitch
      • Victor Vector
      3599
      Composite Shape
      3673
    • I
      Color palette UI little bug
      • ideagonal
      3819
      @ideagonal This problem should be fixed in 1.1.048
      Closing path messing up first segment
      • gentlecl
      3450
      @gentlecl This problem should be fixed in 1.1.048
      Layer panel , colour selector issue
      • gentlecl
      4092
    • Unexpected and unwanted color mode changes
      8558
      @Ingolf This problem should be fixed in build 1.1.048
    • Cutting live text and pasting it in the document does not work
      3518
      @Boldline This problem should be fixed in build 1.1.048
    • macOS - Paste Inside replaces objects when clipboard contains raw text
      4955
    • Automated email bug reporter after crash sends email when the "enter" key is pressed.
      • Victor Vector
      5289
      @VectorStyler I encounter crash with pen tool, but when restart the program bug reporter poped up.
      Pen tool crash the program
      2755
      @Jayanta-Das This seems to be a regression in the Apperance panel.
    • Adding image effects to locked layers - usability
      3118
    • Double path in outline mode
      4975
