    Artboard Placement Y-axis issue
    4 Posts 2 Posters 4.8k Views 2 Watching
    • Victor VectorV Offline
      Victor Vector
      Hi,
      Artboard placement lead to an unexpected error.
      Created a 100 x 100 pt. artboard, in the Transform Panel, set the Transform Panel's origin point to the upper left. From the Canvas Panel access the Artboard Options:
      As you can see, when a 100 x 100 pt. artboard is set to a 0 pt. vertical placement (Y-axis) it displays 0 pt. in the Artboard Options.
      • Selecting the Artboard with the Artboard Editor Tool, accessing the Transform Panel, having the origin point set to the upper left, shows the artboard as being 512 pt. on the Y axis.
      • Switching the value back to zero in the Transform Panel will show it incorrectly in the Artboard Options.
      • Switching the value back to zero in the Artboard Options will show it incorrectly in the Transform Panel.
        Here is my sample file: 0_1650550024440_Artboard placement.vstyler
        VectorStyler @Victor Vector
        @Victor-Vector I will add this to the backlog. The issue is probably caused by the top-down coordinate mode.
        Also: the Artboard Options view always shows the bottom-left corner position (origin) of the artboard, regardless what is selected in the transform panel.
        Victor VectorV 1 Reply Last reply Reply Quote 0
          Victor Vector @VectorStyler
          @vectoradmin I appreciate that you offer the two types of coordinate modes (If users are looking for this option, it is located in File > Document Setup > General under Top-Down Coordinates).
          So, typing aloud, just to make sure I got this correct, Top-Down Coordinates checked means that positive numbers increase as the Y-axis goes "down".
          • This option can be more intuitive for desktop publishing and print outputs since a multiple page layout usually flows from left-right, top-bottom.
          • But in the mathematical graphing world, the positive numbers increase as the Y-axis goes "up".
            Again, nice to have the options; I see value with both modes!
          With regard to the Artboard Options > Place view always showing the origin from the bottom-left corner origin of the artboard, I would suggest three options for user clarity:
          1. In the Artboard Options > Place view add some text near the Horizontal and Vertical fields that says something like: "Origin point: bottom-left corner."
          2. Or, have the origin automatically switch in the Artboard Options > Place view when File > Document Setup > General > Top-Down Coordinates is checked.
          3. Or, have one of those object origin gizmos (is that the proper terminology?!) in the Artboard Options > Place view, near the horizontal and vertical numeric fields.
            @Victor-Vector This problem should be fixed in 1.1.048
