    • Layer highlight selection color
      8498
      @vectoradmin said in Layer highlight selection color: @Arde These colors can be customized: Thanks, I had completely missed that dropdown control. Huge level of customizability you have! Yes, I think there might be point in using defaults that are close to ones used in Illustrator or Affinity apps.
      Printing to CMYK separations does not work
      • Arde
      4742
      @Arde CMYK color separation and related issues have been fixed in the new build.
      Separation printing (CMYK) does not honor hidden inks setting
      • Arde
      3716
      @Arde This issue has been fixed in the new build.
      Exported EPS from Halftone adjustment causes crash when imported back
      • Arde
      4046
      @Arde This issue has been fixed in the new build. The EPS file exporting with adjustment layer was broken.
    • History panel jumps
      4103
      @Boldline The history list jumping has been fixed in the new build.
    • Path Brush Jitters and cursor size
      9292
      @Boldline The issue is caused by stroke expansion on complex shapes. The cleanup scheme is not working well. This is in the backlog, but the fix will not be soon.
    • Application Shortcuts -> search not working?
      • syllie
      9367
      @syllie To continue the search for an action, click on the search icon at the start of the search field.
    • VectorStyler does not work on multiple screens
      • VectorWhiz
      5876
      @VectorWhiz Multiple screen handling has been improved in the new build. The problems were the same on Windows and Mac versions.
    • Docking panels at top overlaps side panel on right side
      5685
      Opened a bug on this one. Meanwhile, panels can also be closed by selecting the (checked) menu item in the Panels menu.
    • A lot of tooltips are incorrect (Windows)
      • syllie
      6408
      @syllie If any tool tips are wrong or missing, please let me know. The bug was about the Windows adaptation layer not handling tool tips correctly.
    • Pointer changes unexpectedly (visual bug)
      • syllie
      3908
      This is fixed in build 1.0.018 RC1 on Win10. Thank you!
    • Preferences > Changing Settings > Don't extend with pencil
      • syllie
      3994
      I can see this working as expected in build 1.0.018 RC1 on Win10. Thanks!
    • Selecting / deselecting path writes 'move' to history, even if not moved
      • syllie
      8936
      @vectoradmin With build 1.0.018 RC1 this is now resolved on Win10. Thank you!
    • About Object> Transform> [Scale], [Skew], [Rotate], [Reflect]
      6512
      @861475_VctSt Set them on by default.
    • Application Crash and Crash Report Function
      • syllie
      3915
      Hi, I just sent you a similar file. It definitely was from the offset path options dialog in the shape effects panel. More details in the email.
    • Grouped set of Objects auto-un-groups?
      4132
      ok - i think i see what you mean - I am checking that out now - it may solve the other post I just made and allowing for individual shape edits and moving within an existing grouping update: yes that was my issue.. I was able to use the context panel options to achieve what i wanted with that. I like the dialed down specificity of each option and how it's all within the transform tool. It will take my brain a little time to re-learn it!
    • Objects rotate instead of merging - boolean
      6642
      @Boldline I got the file. When I try to merge those 3 objects (top 2 path and the group) the objects stay in place. Seems that something is different in this file and the video. I will look into this more.
    • Offset path does not cancel edit when task is canceled in panel
      7286
      ok that makes sense. When using the destructive method - when i do intentionally commit to the change, it leaves a copy of the original shape behind. So I end up with two shapes in the end - the initial shape and the modified shape. I wasn't sure at first if I liked that or not - so used to copying the initial shape to memory, doing an offset path and then pasting in place over top, the original piece again (in illustrator). your method of leaving the initial shape there and creating a new shape means it is not 100% destructive (I can still access the original) and I don't have to remember to make a copy of the initial piece before i use offset path
    • "Object"> "Object Hiddenn" does not work.
      6034
      @vectoradmin From the point of view of the unity of the software as a whole, there may be room for consideration. It may be better to "display" and "hide" with toggle on and toggle off.
    • Star Panel "Level" option up arrow faulty
      4338
      if it helps any, this happened repeatedly in that session. Several times I would bring the number down using the down arrow for the "line" option but as soon as I hovered over the up arrow, it raced up super fast to 8 again. It did not work properly again until I closed out that panel and double clicked to make a new one and tried again.
