Issues with launching context menu.
I had a few crashes in latest build already. There are some problems with context menu.
- Got a feeling that context menu appear when button's state is pressed.
- Quick press&release of right button is to fast to show menu , but context menu is active. When you click in a place where context menu should apear than it will launch shortcut imidiately without showing menu itself.
- Clicking with right mouse button on unselected shape/text is unpredictable. Sometimes shows context menu and select object another shows only menu.
@encart Yes, there might be an issue with popup menus, as there was a request to select on mouse release. Maybe this should not be the case for the context menu.
@encart Just tested this, and it can be replicated. Will be fixed in the next build. A workaround till then is to move the mouse a bit away (to the left) before releasing, so it does not fall inside the menu.
I think I should time that release so it does not close immediately, but can still be closed on first release.
