    Some Arc Warps not working
    6 Posts 3 Posters 7.5k Views
      I imported a vector from Illustrator to do a warp not available there and noticed at least one of the arc warp options from the vertical toolbar are missing the correct handles to edit
      Here is a video of it
      I noticed it does not work on native VS shapes either
        @Boldline Looks like that tool (and the one before) does not initialize the warp type. The effect is shown in the Shape Effects panel but the Shape parameter should be Shell Lower (or Upper) in then Shape field.
        Quick workaround is to either create the effect in then Shape Effects panel, or if once created, select the Shell Lower (or Upper) modes in the Shape field.
        In these two cases, the Shape field will show Custom (that is unknown warp).
        Fix will be in the next build.
        The next build will take some time (has been two weeks now), due to a large set of new features related to typography in certain languages 🙂
        861475_VctSt8 1 Reply Last reply Reply Quote 1
          Great! And thanks for the update on the next beta. I was getting a little worried about you haha!
          • 861475_VctSt8 Away
            861475_VctSt @VectorStyler
            @vectoradmin
            I was worried because there was no usual update.
            I respect your work.
            If "certain languages" is CJK, I'm thrilled.
            I'm sorry theme difference.
            LIc. 0 OS10.15.8
            LIc. 1 OS15.7.4
              VectorStyler @861475_VctSt
              @861475_VctSt I will have more info about this later this week 🙂
                @Boldline This should be fixed in the new build (1.0.022).
