Edit path on a "add vertical text on path" change flow direction
When I first edit the path the text is mirrored
@freggern Yes, there seems to be a bug here.
In the Text -> Text on Path view Shape section check the Reversed option to work around this bug.
@freggern This problem should be fixed in build 1.1.008
thx, tested!
