Draw inside issues build 1.1.002 (beta)
Draw inside is now a menu item in build 1.1.002 (beta)
A few issue though (macOS)
- A) Draw inside only works in normal mode after being used in isolated mode first
- B1) In normal mode I then draw inside the shape selected in the layers panel
- B2) If I then select another object in the layers panel and draw, the new object is created inside the previous selected object
@Ingolf Added to the list of bugs
@Ingolf This issue should be fixed in the latest build
Verified as fixed!
