    Alignment Panel Pulldown Seems fixed now
    3 Posts 2 Posters 4.2k Views 1 Watching
      The alignment panel pull down menu from the top right side of the UI still had some funky things going on, It opens with a wide gap still.
      0_1642600971211_14e3bf13-3ea9-4788-bccf-0a8092bda3aa-BLD 2022-01-19 at 09.01.30.png
      UPDATE: I was able to grab the side of the box and pull it back together and so far, each time I open the alignment panel from the top of the UI, it opens correctly... so maybe it is indeed fixed. I'll keep you posted
      0_1642601154989_b9f1fecf-8441-4705-833f-5dd647120a58-BLD 2022-01-19 at 09.05.35.png
        @Boldline Yes, if it has been resized before then the next time is opened, it will keep the size.
          @vectoradmin said in Alignment Panel Pulldown Seems fixed now:
          It was not staying at the corrected size prior to this.... (or maybe it was fixed in the prior build and I did not check?) Regardless, it is not doing wonky things when I try to compress that space anymore and each time I open it now, it's working as it should - so thank you!
