    • PDFs do not export embedded images with a drop shadow
      • Victor Vector
      6259
      @vectoradmin a big thank you for fixing this in 1.1.030!!!
    • 1.1.030 - Using Alt+ modifier on shape operation from context bar to create composite shapes.
      • Victor Vector
      3322
      @vectoradmin Thank you for the explanation. I will adapt for now
      Very Simple Trace
      • fewerjunk
      6067
      @fewerjunk There is still need for improvement in the image trace. I attached the vectors I got with VS.0_1649264673534_imagetrace1.vstyler
      Insert node with "+" key now sets 2 nodes
      4613
      @vectoradmin, fixed now with 1.1.029
      Win 10 - Key repeating doesnt work in VS since 1.1.028
      5277
      @vectoradmin fixed now with 1.1.029
      VS window snaps back to a default position
      5609
      @vectoradmin , wow, that was fast is fixed now
    • Rasterization Movement
      • Sullyman
      4107
      @Sullyman There is a fix related to this issue. There is always a small movement are vector are rasterized to images, but it should be much smaller now.
    • Difficulty quickly editing a node handle
      3941
      @Boldline When hovering over a node, it should change its color and size (unless that was customized). This would indicate if the node will be selected and grabbed when clicked. There could be some kind of "aging" bug that causes issues with the editor in general.
    • Rotate Canvas
      • ambros
      4134
      Thank you. That's excellent news.
      Node and handle
      5638
      @vectoradmin I am thinking this because when the node close with cusp node the handle handle doesnot retract. You can see in this video when I move the handle closer to the node the issue solve to some extent.
    • Cannot drag select to add to an existing selection using the shape editor tool
      10293
      @Boldline I think this could be a regression in the node selection method. EDIT: yes, it is caused by a change in the node selection, I will roll back that for the next build and it will be fixed.
    • Shift+ modifier in path brush and eraser tool does not seem to constrain drawing to a line.
      11609
      @Boldline There is a small change in how the eraser / path brush are handling lines, and will have separate settings from the Pencil tool.
      Difficulties to detach the Toolbox popup group menu
      4976
      @vectoradmin said in Difficulties to detach the Toolbox popup group menu: @Subpath This problem should be fixed now, let me know if it still occurs. is fixed, thank you
    • Visibility of nodes and guides flashing on and off.
      • Qode5
      3415
      As you can imagine this was difficult to capture in a screenshot, but the screenshot of the entire VS window shows that the guides and artboard name are not visible. The second shows the guides and the artboard name. I should also add that the effect seems more prevalent when there are more nodes. Hope this helps.
    • N
      First change to object style won't propagate ( accumulated )
      • Nils
      3478
      N
      @vectoradmin Refresh does help, thanks.
      Stroke width : weird behaviour sometimes
      2652
      @PatrickM I tested the stroke width selection from the Properties panel on an object with no stroke and it is working here (both on Windows and Mac). If there is a short recording of what happens when the object is selected and the Properties panel is used for stroke selection, please link it here, it would help replicating the issue. Thanks.
    • N
      Object style role causes object deletion to not reflect immediately in layers panel ( accumulated )
      • Nils
      2699
      @Nils Replicated, will get fixed in the next build.
    • Selecting with Shift-key doesn't work properly(single file affected)
      4680
      @vectoradmin said in Selecting with Shift-key doesn't work properly(single file affected): @encart said in Selecting with Shift-key doesn't work properly(single file affected): Not present in the new file. Just to clarify: this error occurs only with this one file? Exactly. I created a new file and problem has gone.
    • Toolbox can not be attached
      5191
      @vectoradmin If the panel is lock can we disable or hide the cross button to close the panel. This happened to me many times when I accidentally close the panel.
    • Snapping not working with CTRL key?
      • Victor Vector
      3662
      @vectoradmin Ah! Thank you for your help. I appreciate the configurability of VS.
