    • N
      Setting a shape on an asymmetric object causes displacement ( accumulated )
      • Nils
      11607
      N
      @vectoradmin Ok, thanks. Just to clarify, you do agree that the latest gif I posted showcases a legitimate bug, right? Otherwise I must misunderstand some functionality here.
    • N
      Transform center sometimes not where visually indicated
      • Nils
      8254
      N
      @vectoradmin UPDATE: This same displacement bug happens in the transform shape effect situation when applying a shape aswell. I assume these are deeply connected?
    • N
      Setting a shape on a group within a group offsets the nested group ( accumulated )
      • Nils
      5286
      @Nils yes, working at the top level should be a good workaround for now.
    • Thumbnail Images in the layers panel sometimes appear upside down
      2720
      @Boldline Is that layer inside some transformed layer?
    • New shape editor tool lasso selection option stops functioning
      6074
      @vectoradmin I have a machine running intel, another with the M1 chip and a windows laptop. I'm going to test the function out on all three and see if I can find anything worth sharing about how or when it occurs
    • Shift-C no longer works as intended. Intentional change?
      2756
      @Boldline It seems to be working here. But there is an other regression (or maybe it was there before), selecting shapes while using the anchor tool is not working.
    • Paste to keep position after small amount of panning still an issue
      4935
      @Boldline I will keep it open. Probably panning is not a good condition for this.
    • N
      Created brush presets won't show up in the "Brush presets" panel
      • Nils
      4287
      @Nils said in Created brush presets won't show up in the "Brush presets" panel: May I suggest that clicking the X folds the group instead of completely hiding it. This would likely avoid this confusion. The group can be folded with the arrow. The problem is that if I want a panel showing only a single group, than the others should be hidden.
    • N
      Deleting the only canvas causes creating a new canvas not to work
      • Nils
      4952
      N
      @vectoradmin I see, makes sense.
    • N
      Deleted brush presets and styles not disappearing
      • Nils
      6347
      N
      @vectoradmin I just posted a new bug about created brush presets not showing up in their respective panel. In the corresponding gif you can always see at the end that brush presets, that I created and deleted earlier didn't disappear in the brushes selector. Deleted styles did disappear as soon as I deleted the last path that had them applied. It would be nice if they'd disappear even if there were still applied instances, preferably with the applied instances being deleted aswell. EDIT: I just noticed that if I delete the only applied instance first, in the case of the style, and then the style ( in the styles panel ), then the style only disappears from the brush selector after restarting VS.
    • N
      Role - ..bugs?
      • Nils
      8311
      N
      @vectoradmin Can confirm, they're all fixed. Nice!
    • N
      Some artboard oddities...
      • Nils
      9473
      N
      @vectoradmin Can confirm that that these are all fixed. Very, very nice.
      Select grouped tools in the toolbox.
      • freggern
      8625
      There is sometimes some strange short close und reopen behavior (looks like a timed event that happend after some time)
    • N
      Occasionally buggy interactive transform markers
      • Nils
      10796
      N
      @vectoradmin I've just tried replicating this with a 1 px ellipse and that failed. The handles also seem much more stable. I'll post here should this reoccur.
    • Changing color mode from Default RGB and the viewport goes crazy
      8418
      @vectoradmin <SOLVED> Works fine now
    • Double-clicking to select a word in text, adds the punctuation.
      • Victor Vector
      4301
      @Victor-Vector This problem should be fixed in build 1.1.024
    • WIN key is reducing stroke width?
      • Victor Vector
      3546
      Corner inconsistent.
      8044
      @Jayanta-Das This problem should be fixed in build 1.1.024 For uneven corner sizes, use the Corner editor tool and drag the handles positioned on the shape.
    • Text Labeling Options - Bullets, Numbers not working
      • Victor Vector
      3780
    • Separate Path missing from keyboard shortcut panel?
      4751
