    • Stroke panel not registering stroke sizes under 0.01 - same issue with using the bracket keys
      3261
      @Boldline There is a Preferences -> Number Editors -> Limit Precision option: should be enabled by default but it is not (regression), if disabled, the precision should be better.
    • Pasted vector in VS and resized, reverts back when copied and pasted
      4922
      @Devil-Dinosaur This problem should be fixed in build 1.1.024
    • Moving the whole content of a layer
      • Devil Dinosaur
      4529
      Ruler 0,0 position
      4596
      @Jayanta-Das This problem should be fixed in build 1.1.024
    • Double click on text place the cursor in unexpected places
      3323
      @encart This problem should be fixed in build 1.1.024
    • Double click on existing node doesn't create a new node in the center.
      3466
    • Perfect ellipse values
      3394
      @Ingolf The 0 to 360 ellipse angles should not add a line in the next version of VS.
    • Lock angle (SHIFT plus drag) issue
      6254
      @Ingolf This problem should be fixed in build 1.1.024
    • Pen tool odd behavior
      8036
      @b77 This problem should be fixed in build 1.1.024
    • Shifted side toolbar.
      3404
    • Stroke, fill messes up
      11122
      @Ingolf This problem should be fixed in build 1.1.024, let me know if some problems still occur regarding this.
    • Properties panel feedback
      5336
      @Ingolf (A) should be fixed in build 1.1.024
    • Issues with duplicate as reference
      4081
    • Jumping and sinking panels
      6116
    • Incorrect naming of duplicate of group
      3094
    • Gradient panel and color panel sync issues
      4677
    • Alignment will not work if "Space" setting is literally empty
      4969
    • Toolbar-based warps have a noticeable pullback from where they are released
      3481
    • Recovered files previously unsaved do not "become" the new file
      4771
    • Are saved preference files universal between Mac and PC?
      4158
      @Boldline When transferring files, the theme might be missing on the other computer. If that is the case, VS will use a default theme now.
