    • confusion about how the style/color picker chooses what color or other attributes to copy and apply to the selected object.
      2941
      @Boldline This should be fixed in the 1.2.060 build
    • Unable to switch back to the pen tool by pressing the "p" key, from the stroke width tool to the pen tool
      3175
    • O
      Group Selection Tool?
      • oleGraf
      5861
      @oleGraf In the new build, clicking on selected objects with the "direct" select tool will select the parent (similar as in AI).
      Edit Shape Effect is shown on Objects without any Shape effect
      2373
      @Subpath said in Edit Shape Effect is shown on Objects without any Shape effect: Or is there another option? In the Layers panel there will be a shape effect editing icon shown in the object row.
    • Could edits to a gradient made in gradient panel and modified in repeater update the repeater result?
      3154
      @Boldline I will test these presets.
    • Allow for more immediate custom color choice in colorize panel?
      1615
      @Boldline I will try to add this to the colorizer as it would be a much simpler solution than the replace color.
    • How do I change the color of the repeater results prior to expanding it?
      1595
      @Boldline Only by editing the repeated object color. This can be done by opening the repeater (Symbol Set) object in the Layers panel, selecting the object and then changing the color.
    • Bitmaps placed in VS now lack a transparent background
      2957
      @VectorStyler cool! just tried it out. thanks for the info - no rush on updating the documentation. I was making sure it was known to be added eventually
    • Align to pixel grid
      • syllie
      1662
      @syllie It is an object attribute, but it applies to all objects inside the group having this attribute. But it does not apply to the patter content by default. For that you need to create the pattern content using this attribute on the objects. I will think of a way to make a global attribute that does this.
    • If I pull document tab out from its main position, how do I get it to snap back to its original location?
      1765
      @Boldline Drag the detached document from its title leaf (the "Untitled..." text in the image) and drag it over the area where the attached title leafs supposed to be. There is a thin gray line indicating the area.
    • How do I pull out a tabbed panel from a group?
      3420
      @VectorStyler Thanks. I realized that I had to click off on the "lock all panels" to allow the tabs to be easily pulled out from a grouping.once I unlocked it, I was able to edit the groups of panels as you showed in the video
      Specific values in Grid
      • Kumr
      2170
      @VectorStyler Thanks for the support. Will try that.
    • Repeated clicking does not drill down to lower objects to select
      1815
      @Boldline Only if double clicked for isolation. Or with Option+Click to select an object inside a group.
      VS update?
      • asan
      1622
      @asan The next build should be on app store also (this week).
      Performance issues with Illustrator brushes
      • JuurGroove
      3588
      @JuurGroove said in Performance issues with Illustrator brushes: Though still not as smooth as in Illustrator as far as I can remember When ypu have time, test those scatter brushes against any of the recent Illustrator releases
    • Confused about transform
      • syllie
      8385
      @VectorStyler I'll get some examples next time I start fiddling especially now that I know the zoom matters for snapping
    • Bug Report Window Suggestion
      • debraspicher
      1702
      @debraspicher I will fix this.
    • Altered pivot point doesn't apply
      4964
      Very nice upgrade v. 1.2.057 Now transforming with Transform tool (V) works fine.
      About page
      • monsterfox
      31
      31
      33282
      @VectorStyler I don't think it's necessary. This seems like an action where there are two steps: 1. Create a new canvas, 2. Maximize the canvas display. The shortcut key operation is just for the convenience of adding a canvas. I have also set a separate shortcut key for maximizing the canvas display. I believe most people share my view. This is more in line with the actual operating habits.
      Roadmap & website
      2265
      @VectorStyler thanks, I always end up finding it... I humbly think that this information is interesting for those who visit the website without being particularly interested in the forum.
