• Where is the gradient for scale in a repeater?
    C
    Perfect, thank you. Don't know why I didn't see that.
  • Repeater option to edit shape directly with existing repeater preset
    @VectorStyler oh great! Thank you for fixing that
    @William-Kansepa , interesting I don't see a big problem with that, since it's always easy to use a kind of dummy group (without colors). Or to plan a bit in advance. Alternatively, it is always possible to use multiple mirror groups. By the way, one way I found to add more objects to a mirrored single object works by first creating a Symbol of it. Then you use that Symbol and mirror it. Afterward, you can replace that Symbol with any objects or add more by selecting the objects and using the "Replace Symbol with Selected Object" button in the Symbols panel.
  • Question about the Intertwine Tool
    @Gremriel I tried it out and discovered something interesting. Firstly, I had the same problem as you: the intertwining effect disappeared when I deleted the outline. After that, the intertwining effect couldn't be created again. The reason for this could be that when you ungroup the objects, there are now four copies of the red object. I think this has something to do with the effect itself. If you delete three of the four objects, you can apply the effect again. [image: 1765573674592-intertwine-effect.png]
  • Node Editor vs Shape Editor tools
    @William-Kansepa said in Node Editor vs Shape Editor tools: What are the major differences in functionality between the Node Editor and the Shape Editor tools? yes, this is a new thing in 1.3: Node Editor: will edit the nodes of the top effect, or the object shape Shape Editor: will always edit the object shape, regardless what effect is stacked on it. These two tools are the same of the object contains no shape effects
  • DXF Versions
    @VectorStyler Thanks for the quick reply. If you have some older DXF files that do not import, please send… Thanks, but I'm not really needing that. I'm just making some examples to demonstrate the decades-old "polyline" problem of the CAD>DXF>Bezier workflow (which I don't recommend, if at all avoidable). So I just wanted to make sure not being able to open the R12 files I'm using to demonstrate, is not unique to my installation. I can open R14 versions of the same files, (which do not demonstrate the polylines issue, but break curves at every path segment). JET
  • Not sure how to create a line tapering repeater
    1k Views
    @Boldline said in Not sure how to create a line tapering repeater: What is the best way to create this because [when I do it the usual way, nothing happens.] There are at least more than five ways in Repeater to achieve the result you want. If it must be done using only a single line, with the gradient controlling the line’s thickness, the best way is to use variables. Please see the video. https://youtu.be/Hyg6LJTxftQ
  • Clip to Arboard setting as an icon... is possible?
    @VectorStyler Great! Thanks again. I grouped the three Artboard clip icons (dim outside, clip to artboard and show outside). Very useful. The icons are quite similar, i will make some modifications to identify easily.
  • Search in application
    @VectorStyler Yes is very usefull, specially for newbies like me. Gimp has this feature: [image: 1764952346921-d6909804-0fa3-43ef-97e7-a6fa3c31be50-image.png]
  • Why can't the join tool be invoked in some cases
    @EricP Aha Your welcome Btw. the "Extend Path Tool" could also be helpful in some circumstances by working with Spirals (should converted to curves first of course) [image: 1764673450253-extend-path-tool.png]
  • Files not Exporting
    export artboards
    1k Views
    C
    [image: 1764518985732-26e46ca0-3529-4165-bba5-297080b9dc67-image-resized.png] Here's the export window and me prompting it to save in (D:) [image: 1764519005007-edb17fd7-9f36-49f3-b216-548e8e350a1e-image-resized.png] Not a network, just a partition in my SSD
  • The intertwine feature seems to need yet some fine-tuning
    @VectorStyler That it might be related to antialiasing was also my thought. It's just a minor thing for me, so no need to hurry.
  • Repeater Preview
    @Comet The same happens to me
  • Scale Strokes and Effects
    63
    158k Views
    @gotanidea I will try to find a solution for this
  • Snapping affecting the original position of moved objects
    @VectorStyler said in Snapping affecting the original position of moved objects: What is the active tool? Pen tool
  • Disabling construction lines
    @Fertuffo there is an option to disable snap overlays in the snapping option panel [image: 1764323324058-2e73a028-9aa9-45a0-bd8c-ae042e992860-image-resized.png]
  • Did not receive license after payment
    D
    @VectorStyler Thank you!
  • Default zoom level?
    nocturnalYLN
    OK, got it.
  • IMport svg produves rasterized image
    @gentle Can you send me the SVG file ?
  • PEn tool direction handle isn't visible after a few strokes
    @gentle Clearly there is a bug here, I will try to fix this as soon as possible.
