      Symbol Tinting Brush only works one time
      • fde101
      4992
      @fde101 I will try to replicate this.
    • The tooltip in the shape effect editor (4-point)
      3890
      @Ingolf This problem should be fixed now.
    • Locked proportional width and height in the shape's properties window.
      3398
      @encart This problem should be fixed now.
    • Offset Path preview disappears when set to under 0.186 inches
      3794
      @Boldline This problem should be fixed now.
    • Offset path not returning final result to 100% - corrected with VS restart
      4270
    • Color panel slider issues - part 1 (hue accuracy)
      4447
      It is
    • Can literally nothing be added or deleted or modified on a locked layer?
      3666
    • Strange behaviour of Radius corner field.
      3617
    • Bolean Exclude gives unexpected results.
      4512
    • [Move window] Have to click 'Cancel' button 3 times to close it.
      3463
      Vertical text in PDF is not proper
      • ash-f
      15903
      @ash-f Font exporting to PDF and Postscript has been significantly improved in recent versions. Let me know if this issue still occurs.
    • Dragging VS to another screen and back causes issues
      3572
      @Boldline Tried to replicate this with a Mac Mini dual screen setup, but could not. Is the problem still occurring?
    • Color panel slider issues - part 4 (too much accurary?)
      3613
      @Ingolf This problem should be fixed now. BTW: enable Preferences -> Number Editors -> Limit Precision, to scroll with reasonable amounts.
    • Color panel slider issues - part 2 (brightness accuracy)
      3607
    • Parts of Design Disappear Momentarily as I edit other parts
      4027
      @Boldline There have been improvements in using dual display setups. Let me know if this issue occurs.
      Automatic Vertical Roman option not working properly
      • ash-f
      5758
      @ash-f This problem should be fixed now.
    • Holding down shift causes node path to go wonky
      6716
      @Boldline Holding down Shift key will restrict to horizontal or vertical movement only.
    • Align to selection does not seem to be working as it should
      3954
      @Boldline Aligning selected nodes with the Alignment panel should work now.
    • Referenced duplicate+source and clone source not exported to SVG
      7626
      @Ingolf Exporting reference objects (with Named Groups option enabled) should work now.
    • Change color mode - stroke goes from none to color
      4511
      @Ingolf There is a Select Color Mode option in the Color panel menu, to control whether the color mode change causes the selection of the color or not.
