Change color mode - stroke goes from none to color
Draw shape with pen tool - switch foreground and background color (fill now black, stroke none)
Change color mode from rgb til hls
Stroke is now black (on exactly stroke, because stroke is still active, in front)
Set stroke to none
Change color mode
Stroke is set here as well
Selecting another color mode should never actually set a color on an object
Switching colors between stroke and fill should probably also affect which one is in front, active
@Ingolf Setting the color mode will select the color to the selected object, by design. The color mode is also stored with the object.
I will think of a way to avoid setting the color mode if the object has no fill (or stroke). Or maybe make this an option (panel menu).
About switching the color target: this could be done, but none of the other apps do this, so I'm a bit worried about the expectations of new users.
@vectoradmin said in Change color mode - stroke goes from none to color:
I will think of a way to avoid setting the color mode if the object has no fill (or stroke). Or maybe make this an option (panel menu).Not a big issue for me
If you solve it I don't think you have to make it another setting. Toggling mode is not a color choosing action, so I wouldn't expect anything to happen in the color chooser when selecting another color mode.
You are right - this is how it works in Illustrator, Affinity and others so better if you stay in sync with them.
@Ingolf There is a Select Color Mode option in the Color panel menu, to control whether the color mode change causes the selection of the color or not.
