    Offset path not returning final result to 100% - corrected with VS restart
    4 Posts 2 Posters 4.6k Views 1 Watching
      I am still occasionally getting situations where the offset path does not produce a final output at 100% opacity. the source vector is at 100% and then after the offset path is applied, it often stays at 60% opacity. You can see it in this video.
      I know this has been discussed before and a restart of VS does fix the problem for a while and then it reoccurs down the road sometime.
        @Boldline Yes there is an open bug on this one. It has not been replicated yet.
          @vectoradmin no problem or pressure intended. the issue popped up and I was able to record it before moving on. Glad it's on the bug list 🙂
            @Boldline This problem should be fixed now.
