Object partially masked doesn't render at export
Hi everyone,
The title spoiled it...
I'm exporting an illustration and one object doesn't appear (both JPG and PNG). It's an object with noise + a mask layer with gradient+blur (yes, I reached the limit of my computer). I think the combination mask + noise + blur is the problem since I already exported a mask with a gradient (but without noise nor blur). Most likely the combination of the 3 or the blur is the cause (mask+noise alone seems OK).
Here below you can see the export and how it looks in VS.
@Devil-Dinosaur Was this exported to PDF?
I will try to replicate the combination of effects for exporting.
I have simplified my drawing by using 1 less object. But the road noise doesn't export and render when it has the mask. PDF is even worst, totally forgetting some objects. I will send you the scenery VS file and my renders by e-mail if you can have a look. Thank you.
Maybe I was wrong in exporting in RGB, since the VS file is CMYK.
CMYK jpg seems OK on my last try...
@Devil-Dinosaur RGB exporting should also work, it is a bug if not.
But one important thing: image effects have a different result on RGB than CMYK, since they are applied in the document color mode.
@Devil-Dinosaur This problem should be fixed in 1.1.048
